PSP 300x Analog Stick Replacement
Views: 53K
View statistics:
Past 24 Hours:
21
Past 7 Days:
179
Past 30 Days:
663
All Time:
53,195
Comments: 15
13 comments on steps, 2 guide comments.
Go to guide comments
Completed: 25
25 people have marked this guide "completed." Will you be next?
Favorites: 12
12 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
Guide for removing the Analog stick in a Sony PSP-3000
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. PSP 300x Analog Stick Replacement, Battery: step 1, image 1 of 3 PSP 300x Analog Stick Replacement, Battery: step 1, image 2 of 3 PSP 300x Analog Stick Replacement, Battery: step 1, image 3 of 3
      • Place the PSP face down and locate the battery cover on the left side of the device.
      • Lift and remove the battery cover to reveal the battery.
      • Remove the battery.
      Ask FixBot
    1. PSP 300x Analog Stick Replacement, Front Casing: step 2, image 1 of 1
      • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
      Ask FixBot
    2. PSP 300x Analog Stick Replacement: step 3, image 1 of 2 PSP 300x Analog Stick Replacement: step 3, image 2 of 2
      • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
      • Two are located behind the battery's warranty sticker.
      • Two are located on the right side of the PSP.
      Ask FixBot
    3. PSP 300x Analog Stick Replacement: step 4, image 1 of 1
      • Next, unscrew the two screws located at the top of the PSP.
      Ask FixBot
    4. PSP 300x Analog Stick Replacement: step 5, image 1 of 1
      • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
      Ask FixBot
    5. PSP 300x Analog Stick Replacement: step 6, image 1 of 2 PSP 300x Analog Stick Replacement: step 6, image 2 of 2
      • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
      • Remove the front casing completely.
      Ask FixBot
    1. PSP 300x Analog Stick Replacement, LCD Screen: step 7, image 1 of 2 PSP 300x Analog Stick Replacement, LCD Screen: step 7, image 2 of 2
      • Push the homebar to the right to release the tab located on the right side of the LCD screen.
      • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
      Ask FixBot
    2. PSP 300x Analog Stick Replacement: step 8, image 1 of 3 PSP 300x Analog Stick Replacement: step 8, image 2 of 3 PSP 300x Analog Stick Replacement: step 8, image 3 of 3
      • Slowly lift the LCD screen off the PSP starting at the top edge corner.
      • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
      • Orientation of PSP is flipped in photo.
      Ask FixBot
    3. PSP 300x Analog Stick Replacement: step 9, image 1 of 2 PSP 300x Analog Stick Replacement: step 9, image 2 of 2
      • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
      • Pull all four ribbon cables out.
      • Now remove the LCD screen and homebar from the PSP.
      Ask FixBot
    4. PSP 300x Analog Stick Replacement: step 10, image 1 of 1
      • Remove the metal tab that lies above the LCD screen.
      • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
      Ask FixBot
    1. PSP 300x Analog Stick Replacement, Trigger Buttons: step 11, image 1 of 1
      • Remove the screw securing 'L' trigger to the PSP.
      Ask FixBot
    2. PSP 300x Analog Stick Replacement: step 12, image 1 of 1
      • Remove the white plastic piece that holds the 'L' trigger in place.
      Ask FixBot
    3. PSP 300x Analog Stick Replacement: step 13, image 1 of 1
      • Remove the 'L' trigger from the PSP.
      Ask FixBot
    4. PSP 300x Analog Stick Replacement: step 14, image 1 of 1
      • Remove the screw securing the 'R' trigger.
      Ask FixBot
    5. PSP 300x Analog Stick Replacement: step 15, image 1 of 1
      • Remove the white plastic piece that holds the 'R' trigger in place.
      Ask FixBot
    6. PSP 300x Analog Stick Replacement: step 16, image 1 of 1
      • Remove the 'R' trigger from the PSP.
      Ask FixBot
    1. PSP 300x Analog Stick Replacement, Analog Stick: step 17, image 1 of 1
      • Remove the screw from the bottom left edge of the PSP.
      Ask FixBot
    2. PSP 300x Analog Stick Replacement: step 18, image 1 of 1
      • Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
      Ask FixBot
    3. PSP 300x Analog Stick Replacement: step 19, image 1 of 2 PSP 300x Analog Stick Replacement: step 19, image 2 of 2
      • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
      • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
      Ask FixBot
    4. PSP 300x Analog Stick Replacement: step 20, image 1 of 1
      • Remove the cable from the connector and remove the entire black piece from the PSP.
      Ask FixBot
    5. PSP 300x Analog Stick Replacement: step 21, image 1 of 1
      • Remove the screw holding the analog stick in place.
      Ask FixBot
    6. PSP 300x Analog Stick Replacement: step 22, image 1 of 2 PSP 300x Analog Stick Replacement: step 22, image 2 of 2
      • Flip up the lock on the analog sticks ribbon cable.
      • Remove the analog stick from the PSP.
      Ask FixBot
25 other people completed this guide.
mbnewsom
3,551 Reputation
11 Guides authored
2 Guide Comments
Thank you for the tutorial, and I learned a lot!
Charda Eben Haezer - Reply Share
Thank you so much!!! you are the best!!!
Hisler Sadeck - Reply Share
Past 24 Hours: 21
Past 7 Days: 179
Past 30 Days: 663
All Time: 53,195
