PSP 3000 Power Switch Circuit Board Replacement
    1. PSP 3000 Power Switch Circuit Board Replacement, Power Switch Circuit Board: step 1, image 1 of 2 PSP 3000 Power Switch Circuit Board Replacement, Power Switch Circuit Board: step 1, image 2 of 2
      • Push the latch and detach the battery panel to expose the battery pack.
      • Take the battery out.
      Ask FixBot
    2. PSP 3000 Power Switch Circuit Board Replacement: step 2, image 1 of 3 PSP 3000 Power Switch Circuit Board Replacement: step 2, image 2 of 3 PSP 3000 Power Switch Circuit Board Replacement: step 2, image 3 of 3
      • Remove the all screws seen and the hidden screw.
      Ask FixBot
    3. PSP 3000 Power Switch Circuit Board Replacement: step 3, image 1 of 2 PSP 3000 Power Switch Circuit Board Replacement: step 3, image 2 of 2
      • Remove the screwed panel on the opposite side of the PSP.
      Ask FixBot
    4. PSP 3000 Power Switch Circuit Board Replacement: step 4, image 1 of 2 PSP 3000 Power Switch Circuit Board Replacement: step 4, image 2 of 2
      • Rotate your PSP so that the bottom is facing you and remove the remaining screws.
      Ask FixBot
    5. PSP 3000 Power Switch Circuit Board Replacement: step 5, image 1 of 3 PSP 3000 Power Switch Circuit Board Replacement: step 5, image 2 of 3 PSP 3000 Power Switch Circuit Board Replacement: step 5, image 3 of 3
      • Rotate once more with the top facing you and unscrew the last screws.
      • The front panel of your PSP can now be lifted off and expose inside the body of the PSP.
      Ask FixBot
    6. PSP 3000 Power Switch Circuit Board Replacement: step 6, image 1 of 2 PSP 3000 Power Switch Circuit Board Replacement: step 6, image 2 of 2
      • Carefully take out the power switch circuit board on the bottom right side of the PSP.
      Ask FixBot
    7. PSP 3000 Power Switch Circuit Board Replacement: step 7, image 1 of 1
      • Use your finger nails to lift the black latch shown in the picture.
      • Remove the ribbon wire.
      Ask FixBot
    8. PSP 3000 Power Switch Circuit Board Replacement: step 8, image 1 of 2 PSP 3000 Power Switch Circuit Board Replacement: step 8, image 2 of 2
      • Insert the new power switch circuit board.
      • Latch the ribbon wire onto the black latch.
      Ask FixBot
Replacing the power switch circuit board in the PSP-3000 restores control over the system’s power and hold functions, which solves many problems caused by a failing switch assembly. Carefully removing the lower button bar, disconnecting ribbon cables, and installing a new circuit board can safely eliminate problems, such as a bad startup, unexpected shutdowns, or systems getting stuck in HOLD mode. While the repair demands patience and attention to very delicate internal components, completion ensures that the PSP-3000 can once again operate smoothly and respond correctly to power commands, further extending the life and usability of the device.
Javier Rodriguez
158 Reputation
1 Guide authored
CSU Los Angeles, Team 5-4, Grodsky Fall 2025 Member of CSU Los Angeles, Team 5-4, Grodsky Fall 2025
CSULA-GRODSKY-F25S5G4
4 Members
12 Guides authored
1 Guide Comment
How about board without black clip bro ? I buy power on board without clip..
nurmuhdrassul - Reply Share
Past 24 Hours: 12
Past 7 Days: 45
Past 30 Days: 220
All Time: 1,065
