Up to 20% off select tools
PSP 2000 UMD Drive Replacement
Views: 79K
View statistics:
Past 24 Hours:
39
Past 7 Days:
181
Past 30 Days:
842
All Time:
78,804
Comments: 16
12 comments on steps, 4 guide comments.
Go to guide comments
Completed: 35
35 people have marked this guide "completed." Will you be next?
Favorites: 34
34 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Difficult
Parts
Tools
Introduction
Go to step 1 ↓
Having trouble reading discs? This guide is for you!
    1. PSP 2000 UMD Drive Replacement, Battery: step 1, image 1 of 3 PSP 2000 UMD Drive Replacement, Battery: step 1, image 2 of 3 PSP 2000 UMD Drive Replacement, Battery: step 1, image 3 of 3
      • Place PSP face down, so that the UMD Drive is facing upwards.
      • Locate the battery door and open.
      • Remove the battery from inside.
      Ask FixBot
    1. PSP 2000 UMD Drive Replacement, Front Casing: step 2, image 1 of 1
      • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
      • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
      • Remove the sticker using the PSP Opening Tools.
      • Under the sticker is a 5mm Phillips screw needed in the next step.
      Ask FixBot
    2. PSP 2000 UMD Drive Replacement: step 3, image 1 of 2 PSP 2000 UMD Drive Replacement: step 3, image 2 of 2
      • Remove four 5 mm Phillips from the case.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      Ask FixBot
    3. PSP 2000 UMD Drive Replacement: step 4, image 1 of 2 PSP 2000 UMD Drive Replacement: step 4, image 2 of 2
      • Remove the following screws from around the bezel:
      • Two 4 mm Phillips
      • One 5 mm Phillips
      • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
      Ask FixBot
    4. PSP 2000 UMD Drive Replacement: step 5, image 1 of 2 PSP 2000 UMD Drive Replacement: step 5, image 2 of 2
      • Gently pry the front bezel away from the casing using a PSP opening tool.
      • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
      • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
      Ask FixBot
    1. PSP 2000 UMD Drive Replacement, Display: step 6, image 1 of 3 PSP 2000 UMD Drive Replacement, Display: step 6, image 2 of 3 PSP 2000 UMD Drive Replacement, Display: step 6, image 3 of 3
      • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
      • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
      Ask FixBot
    2. PSP 2000 UMD Drive Replacement: step 7, image 1 of 3 PSP 2000 UMD Drive Replacement: step 7, image 2 of 3 PSP 2000 UMD Drive Replacement: step 7, image 3 of 3
      • With the home bar out of the way, gently pry up the display using the opening tools.
      • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
      • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
      • Gently lift out the display.
      Ask FixBot
    1. PSP 2000 UMD Drive Replacement, UMD Drive: step 8, image 1 of 2 PSP 2000 UMD Drive Replacement, UMD Drive: step 8, image 2 of 2
      • Carefully disconnect the UMD drive ribbon cable from the logic board. Use the PSP opening tools to push the black tabs on the connector horizantally to free the cable.
      • This connector cannot be removed vertically. Doing so will damage the connector and/or ribbon cable.
      • At this point it is useful to tape the loose metal parts with some masking tape so they don't fall out whilst you have the PSP the other way up.
      Ask FixBot
    2. PSP 2000 UMD Drive Replacement: step 9, image 1 of 2 PSP 2000 UMD Drive Replacement: step 9, image 2 of 2
      • With the front side of the PSP facing you, locate small white plastic box with metal spring attached.
      • Remove the white plastic box and spring from the PSP.
      • If you do not fully remove the spring, there is a risk of breaking the UMD Drive door while disassembling.
      Ask FixBot
    3. PSP 2000 UMD Drive Replacement: step 10, image 1 of 3 PSP 2000 UMD Drive Replacement: step 10, image 2 of 3 PSP 2000 UMD Drive Replacement: step 10, image 3 of 3
      • Position the PSP so that the UMD Device is facing upwards.
      • With the UMD drive open, locate the aluminum UMD eject bracket. Pinch upper arms inwards to dislocate them from the UMD door.
      • The UMD eject bracket can now be easily pulled out.
      • Gently pry on the left side of the UMD door to remove it.
      • Be careful not to break off plastic knobs that secure the door in place, otherwise the UMD Drive will not open properly.
      Ask FixBot
    4. PSP 2000 UMD Drive Replacement: step 11, image 1 of 2 PSP 2000 UMD Drive Replacement: step 11, image 2 of 2
      • With the UMD door off, locate and remove the four 4mm Phillips screws that hold in the UMD Drive in place.
      • If you have not disconnected the UMD ribbon cable, do so now, as to not damage it when removing the drive.
      • If you have not disconnected the UMD ribbon cable do so now, as to not damage it when removing the drive.
      Ask FixBot
    5. PSP 2000 UMD Drive Replacement: step 12, image 1 of 2 PSP 2000 UMD Drive Replacement: step 12, image 2 of 2
      • With the four screws unscrewed, the UMD Drive can be removed. Gently lift the drive from its housing.
      • Make sure as to not damage the UMD ribbon cable (connecting it to the logic board) as you remove the drive.
      • This may be a good time to clean the laser head or any of the components inside the UMD Drive.
      Ask FixBot
35 other people completed this guide.
Author
with
pepe32290
1,803 Reputation
4 Guides authored
Cal Poly, Team 6-3, Maness Fall 2009 Member of Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Members
108 Guides authored
4 Guide Comments
I've used this guide multiple times and it is simply the best out there. You should simply title it "PSP disassembly" as I have used it just to take the 2000 apart and not just replace the UMD drive.
Lisa Lemons - Reply Share
This guide was very helpful in replacing the UND drive in my 2000. Unfortunately, it turns out that the UMD drive was not causing the issue it is having.
Ovismue Veholkin - Reply Share
Lots of guessing in this guide, better not use it and look up a YT video.
Thijs van Ulden - Reply Share
will this be coming back in stock??
Alex McDaniel - Reply Share
Past 24 Hours: 39
Past 7 Days: 181
Past 30 Days: 842
All Time: 78,804
