Up to 20% off select tools
PSP 2000 Front Casing Replacement
Views: 34K
View statistics:
Past 24 Hours:
9
Past 7 Days:
101
Past 30 Days:
441
All Time:
34,171
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 18
18 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Paint job scratched? Going custom? Change out your faceplate assembly!
    1. PSP 2000 Front Casing Replacement, Battery: step 1, image 1 of 3 PSP 2000 Front Casing Replacement, Battery: step 1, image 2 of 3 PSP 2000 Front Casing Replacement, Battery: step 1, image 3 of 3
      • Place PSP face down, so that the UMD Drive is facing upwards.
      • Locate the battery door and open.
      • Remove the battery from inside.
      Ask FixBot
    1. PSP 2000 Front Casing Replacement, Front Casing: step 2, image 1 of 1
      • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
      • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
      • Remove the sticker using the PSP Opening Tools.
      • Under the sticker is a 5mm Phillips screw needed in the next step.
      Ask FixBot
    2. PSP 2000 Front Casing Replacement: step 3, image 1 of 2 PSP 2000 Front Casing Replacement: step 3, image 2 of 2
      • Remove four 5 mm Phillips from the case.
      • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
      Ask FixBot
    3. PSP 2000 Front Casing Replacement: step 4, image 1 of 2 PSP 2000 Front Casing Replacement: step 4, image 2 of 2
      • Remove the following screws from around the bezel:
      • Two 4 mm Phillips
      • One 5 mm Phillips
      • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
      Ask FixBot
    4. PSP 2000 Front Casing Replacement: step 5, image 1 of 2 PSP 2000 Front Casing Replacement: step 5, image 2 of 2
      • Gently pry the front bezel away from the casing using a PSP opening tool.
      • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
      • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
      Ask FixBot
18 other people completed this guide.
Author
with
pepe32290
1,803 Reputation
4 Guides authored
Cal Poly, Team 6-3, Maness Fall 2009 Member of Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Members
108 Guides authored
2 Guide Comments
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - Reply Share
sorry this is a decade too late HA. i just did a swap for the plastic screen cover and yes, for anyone in the future, the plastic cover is on the front shell piece, you will need some tweezers or something narrow to get the plastic screen popped off, dont crack the front shell, the bottom gets fragile so just be slow and methodical. but its an easy swap, maybe 15 minutes. good time to clear out the lint around the joystick as well.
Scott Munier - Reply Share
Past 24 Hours: 9
Past 7 Days: 101
Past 30 Days: 441
All Time: 34,171
