Up to 20% off select tools
PSP 1000 Buttons Replacement
Views: 108K
View statistics:
Past 24 Hours:
34
Past 7 Days:
206
Past 30 Days:
940
All Time:
107,847
Comments: 23
10 comments on steps, 13 guide comments.
Go to guide comments
Completed: 36
36 people have marked this guide "completed." Will you be next?
Favorites: 32
32 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The PSP's buttons may become jammed or may not function properly. This guide will show how to access the buttons for repair, cleaning, or replacement.
    1. PSP 1000 Buttons Replacement, Battery: step 1, image 1 of 1
      • Turn the PSP over so its back is facing you.
      Ask FixBot
    2. PSP 1000 Buttons Replacement: step 2, image 1 of 2 PSP 1000 Buttons Replacement: step 2, image 2 of 2
      • Locate the battery casing button on the rear-left side of the PSP.
      • Press down the button and remove the battery cover.
      Ask FixBot
    3. PSP 1000 Buttons Replacement: step 3, image 1 of 2 PSP 1000 Buttons Replacement: step 3, image 2 of 2
      • Using your finger, remove the battery upwards from the system as shown.
      Ask FixBot
    1. PSP 1000 Buttons Replacement, Front Casing: step 4, image 1 of 1
      • Remove the four screws shown with a Phillips #00 screwdriver.
      • You will have to peel back the warranty sticker to access the lower screws.
      Ask FixBot
    2. PSP 1000 Buttons Replacement: step 5, image 1 of 2 PSP 1000 Buttons Replacement: step 5, image 2 of 2
      • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
      • Remove the two screws from the back righthand side within the holes.
      Ask FixBot
    3. PSP 1000 Buttons Replacement: step 6, image 1 of 2 PSP 1000 Buttons Replacement: step 6, image 2 of 2
      • Gently separate the outer plastic casing from the rest of the system as shown.
      Ask FixBot
    1. PSP 1000 Buttons Replacement, Buttons: step 7, image 1 of 3 PSP 1000 Buttons Replacement, Buttons: step 7, image 2 of 3 PSP 1000 Buttons Replacement, Buttons: step 7, image 3 of 3
      • If the Arrow Buttons are not functioning properly, flip over the outer casing and locate the inside of the buttons, as shown
      • Carefully remove the black rubber backing off of the buttons.
      • Clean the inside of the rubber and the outside of the buttons with a cloth.
      Ask FixBot
    2. PSP 1000 Buttons Replacement: step 8, image 1 of 2 PSP 1000 Buttons Replacement: step 8, image 2 of 2
      • If needed, replace the old buttons with a new set (which can be purchased from Sony or other electronics stores).
      • Carefully re-insert the buttons. This should not require excess force, as the buttons should fit if they are arranged correctly.
      • Gently re-apply the back rubber to the back of the buttons.
      Ask FixBot
    3. PSP 1000 Buttons Replacement: step 9, image 1 of 2 PSP 1000 Buttons Replacement: step 9, image 2 of 2
      • If function buttons (x, square, circle, triangle) need to be replaced, find the corresponding black rubber backing on the inside of the casing.
      • Carefully remove the back rubber to expose the rear side of the buttons as shown. (This can be done using your hands.)
      Ask FixBot
    4. PSP 1000 Buttons Replacement: step 10, image 1 of 2 PSP 1000 Buttons Replacement: step 10, image 2 of 2
      • Next, carefully clean the receiving end of the buttons on the motherboard (shown on picture) with a cloth.
      • If the buttons are clearly damaged, then they need to be replaced.
      • Add the new ones in the form, with the correct button order. (The correct button order has the Triangle on the top, Square on the right, Circle on the left, and X on the bottom).
      • Be very careful! The buttons only go in one way. If you have trouble fitting them in, rotate them in their given spots until they fit in easily. Do NOT force them. Forcing the buttons in may cause damage.
      Ask FixBot
    5. PSP 1000 Buttons Replacement: step 11, image 1 of 1
      • Once buttons are correctly replaced, the back rubbers are fit back onto the buttons, refer back to Replacing the Housing to reattach the casing.
      Ask FixBot
36 other people completed this guide.
Author
with
Henry Lee
926 Reputation
4 Guides authored
Cal Poly, Team 5-6, Forte Winter 2010 Member of Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Members
72 Guides authored
13 Guide Comments
It's a helpful guide,thx
青木一誠 - Reply Share
Great guide. I highly Recomend this to anyone that needs to replace their PSP buttons
unashamed45 - Reply Share
Otimo guia recomendo.
richardmosman - Reply Share
use magnetised screwdriver i had a normal one and it was a pain in the ass to put those tiny little bastards back
Nagy Dániel - Reply Share
Thank you this was a great guide
BLAISE of BASH - Reply Share
Past 24 Hours: 34
Past 7 Days: 206
Past 30 Days: 940
All Time: 107,847
