PSKONTORORA LBER-P4-05 Touchpad Replacement
  1. PSKONTORORA LBER-P4-05 Touchpad Replacement, Battery: step 1, image 1 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement, Battery: step 1, image 2 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement, Battery: step 1, image 3 of 3
    • Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
    • Gently peel the battery off of the motherboard.
    • Be sure not to bend or puncture the battery during removal.
    Ask FixBot
  2. PSKONTORORA LBER-P4-05 Touchpad Replacement, Touchpad: step 2, image 1 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement, Touchpad: step 2, image 2 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement, Touchpad: step 2, image 3 of 3
    • Remove the two 10 mm Phillips #1 screws that secure the grips.
    • Remove the grips.
    Ask FixBot
  3. PSKONTORORA LBER-P4-05 Touchpad Replacement: step 3, image 1 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 3, image 2 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 3, image 3 of 3
    • Remove the four 9 mm Phillips #1 screws that secure the rear case.
    • Lift off the rear casing.
    Ask FixBot
  4. PSKONTORORA LBER-P4-05 Touchpad Replacement: step 4, image 1 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 4, image 2 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 4, image 3 of 3
    • Use tweezers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
    • Gently lift the rumble motors out of their housings and set them beside the controller.
    • Take care not to strain or damage the cables.
    • Gently peel off the battery from the motherboard, with care not to bend or puncture the battery.
    • Remove the two 7 mm Phillips #1 screws that secure the motherboard.
    Ask FixBot
  5. PSKONTORORA LBER-P4-05 Touchpad Replacement: step 5, image 1 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 5, image 2 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 5, image 3 of 3
    • Flip up the black ZIF locking flap that secures the touchpad ribbon cable on the top-right edge of the motherboard.
    • Use tweezers or your fingers to gently disconnect the touchpad ribbon cable.
    • While pulling towards you, remove the motherboard.
    • Remove the black plate.
    Ask FixBot
  6. PSKONTORORA LBER-P4-05 Touchpad Replacement: step 6, image 1 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 6, image 2 of 3 PSKONTORORA LBER-P4-05 Touchpad Replacement: step 6, image 3 of 3
    • Remove the touchpad.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 511
