PSKONTORORA LBER-P4-05 Buttons Replacement
  1. PSKONTORORA LBER-P4-05 Buttons Replacement, Rear Case: step 1, image 1 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement, Rear Case: step 1, image 2 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement, Rear Case: step 1, image 3 of 3
    • Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
    • Pull off the handle grips.
    Ask FixBot
  2. PSKONTORORA LBER-P4-05 Buttons Replacement: step 2, image 1 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement: step 2, image 2 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement: step 2, image 3 of 3
    • Remove the four 9 mm Phillips #1 screws that secure the rear case.
    • Lift off the rear case from the controller.
    Ask FixBot
  3. PSKONTORORA LBER-P4-05 Buttons Replacement, Battery: step 3, image 1 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement, Battery: step 3, image 2 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement, Battery: step 3, image 3 of 3
    • Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
    • Gently peel the battery off of the motherboard.
    • Be sure not to bend or puncture the battery during removal.
    Ask FixBot
  4. PSKONTORORA LBER-P4-05 Buttons Replacement, Buttons: step 4, image 1 of 1
    • Remove the two 7 mm Phillips #1 screws holding the board down.
    Ask FixBot
  5. PSKONTORORA LBER-P4-05 Buttons Replacement: step 5, image 1 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement: step 5, image 2 of 3 PSKONTORORA LBER-P4-05 Buttons Replacement: step 5, image 3 of 3
    • Using tweezers, flip up the small black tab holding down the ribbon cable on the top right of the board and unplug the ribbon.
    • While pulling towards you, remove the motherboard.
    • Remove the black plate in front of the buttons.
    Ask FixBot
  6. PSKONTORORA LBER-P4-05 Buttons Replacement: step 6, image 1 of 2 PSKONTORORA LBER-P4-05 Buttons Replacement: step 6, image 2 of 2
    • Remove the silicon contact pads on the buttons.
    Ask FixBot
To reassemble your device, simply follow these instructions in reverse order.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 90
All Time: 1,843
