PSKONTORORA LBER-P4-05 Battery Replacement
  1. PSKONTORORA LBER-P4-05 Battery Replacement, Rear Case: step 1, image 1 of 3 PSKONTORORA LBER-P4-05 Battery Replacement, Rear Case: step 1, image 2 of 3 PSKONTORORA LBER-P4-05 Battery Replacement, Rear Case: step 1, image 3 of 3
    • Remove the two 10 mm Phillips #1 screws that secure each of the handle grips.
    • Pull off the handle grips.
    Ask FixBot
  2. PSKONTORORA LBER-P4-05 Battery Replacement: step 2, image 1 of 3 PSKONTORORA LBER-P4-05 Battery Replacement: step 2, image 2 of 3 PSKONTORORA LBER-P4-05 Battery Replacement: step 2, image 3 of 3
    • Remove the four 9 mm Phillips #1 screws that secure the rear case.
    • Lift off the rear case from the controller.
    Ask FixBot
  3. PSKONTORORA LBER-P4-05 Battery Replacement, Battery: step 3, image 1 of 3 PSKONTORORA LBER-P4-05 Battery Replacement, Battery: step 3, image 2 of 3 PSKONTORORA LBER-P4-05 Battery Replacement, Battery: step 3, image 3 of 3
    • Use blunt tweezers to pull the white battery motherboard connector directly out of its port.
    • Gently peel the battery off of the motherboard.
    • Be sure not to bend or puncture the battery during removal.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 93
All Time: 1,476
