Up to 20% off select tools
PS4 Dualshock 4 trigger reassembly
Views: 56K
View statistics:
Past 24 Hours:
21
Past 7 Days:
195
Past 30 Days:
794
All Time:
56,414
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
I decided to create this guide because i got *triggerred* trying to reassemble the PS4 Dualshock 4 Controller
    1. PS4 Dualshock 4 trigger reassembly, Preparing the triggers: step 1, image 1 of 2 PS4 Dualshock 4 trigger reassembly, Preparing the triggers: step 1, image 2 of 2
      • Remove these two triggers and springs from the backplate.
      • Find which trigger goes on which side and put the springs in the trigger part facing towards the inside of the controller.
      Ask FixBot
    2. PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: step 2, image 1 of 2 PS4 Dualshock 4 trigger reassembly, Attaching the triggers.: step 2, image 2 of 2
      • On these two clips...
      • Push down the trigger until it clicks on both sides.
      • Make sure that the one spring part is inside the rail (marked cyan) and the other outside the whole assembly (green).
      Ask FixBot
    3. PS4 Dualshock 4 trigger reassembly, Connecting the light bar: step 3, image 1 of 1
      • Connect the light bar cable using your fingers. Make sure it is fully pushed down and that is plugged in the right way.
      Ask FixBot
    4. PS4 Dualshock 4 trigger reassembly, Closing the cover: step 4, image 1 of 2 PS4 Dualshock 4 trigger reassembly, Closing the cover: step 4, image 2 of 2
      • close the cover starting from the side of the triggers. Don't worry if it's a bit hard to do so, but be careful so you don't break the plastic between the trigger and the bumper.
      • Push down until it clicks everywhere.
      • Finally, screw in these four screws using a PH0 screwdriver.
      Ask FixBot
Finish Line
27 other people completed this guide.
Author
with
Devnol
3,041 Reputation
4 Guides authored
4 Guide Comments
Thank you so much! I had a ps4 controller that had a broken r2 button and i had gotten a replacement (which is now having battery issues) Today I took the old controller apart… the spring had come out of the rail. That was it!
Dee - Reply Share
This guide is wrong. The top part spring should be inside the trigger, if you look at the other trigger it’s not exposed.
https://pureplaystation.com/wp-content/u...
Angus Yung - Reply Share
Thanks for pointing it out. I do not have this controller anymore as it was from a repair job so unfortunately, I cannot correct it. If you or someone else happens to have one and is able to take high-quality pictures I’d be more than grateful to accept your correction.
Devnol - Reply Share
@angusyung Like you say, swivel one end of the spring into the buttons' cavity and as you line up the placement of the L2/R2 button into the Red marked clips, focus on getting the other end of the spring into the Cyan marked Rail.
dat nekosaka - Reply Share
Past 24 Hours: 21
Past 7 Days: 195
Past 30 Days: 794
All Time: 56,414
