PS Vita Slim Display Replacement
    1. PS Vita Slim Display Replacement, Back Panel: step 1, image 1 of 1
      • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
      • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
      • There are four screws on the back of the device, remove them as shown.
      Ask FixBot
    2. PS Vita Slim Display Replacement: step 2, image 1 of 2 PS Vita Slim Display Replacement: step 2, image 2 of 2
      • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
      • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
      Ask FixBot
    3. PS Vita Slim Display Replacement: step 3, image 1 of 3 PS Vita Slim Display Replacement: step 3, image 2 of 3 PS Vita Slim Display Replacement: step 3, image 3 of 3
      • The next step will require the opening tool.
      • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
      • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
      • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
      Ask FixBot
    4. PS Vita Slim Display Replacement: step 4, image 1 of 1
      • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
      Ask FixBot
    1. PS Vita Slim Display Replacement, Buttons: step 5, image 1 of 3 PS Vita Slim Display Replacement, Buttons: step 5, image 2 of 3 PS Vita Slim Display Replacement, Buttons: step 5, image 3 of 3
      • We are starting on the left side of the device. This is where the D-pad is, or in other words the left, right, up. and down directional pad.
      • The next step is to take the ribbon off of the green casing on the left.
      • Then simply unscrew the two screws holding down the green casing using a J00 bit from the iFixit pro toolkit, they should both be 6.35 mm .
      • Now simply raise the last restraint, a metal bar that is holding the casing down. Once it has been removed you can take off the green casing.
      Ask FixBot
    2. PS Vita Slim Display Replacement: step 6, image 1 of 2 PS Vita Slim Display Replacement: step 6, image 2 of 2
      • After the green casing has been taken off you should be able to see the back of the D-pad.
      • Once it is removed you should be free to interchange the buttons as needed.
      Ask FixBot
    3. PS Vita Slim Display Replacement: step 7, image 1 of 3 PS Vita Slim Display Replacement: step 7, image 2 of 3 PS Vita Slim Display Replacement: step 7, image 3 of 3
      • Now it is time for the right side buttons. Which is the replacement of the D-Pad on the right side or in other words, where the box, triangle, circle, and X buttons are.
      • First step is the removal of the ribbons on the green casing.
      • Once the ribbons have been removed, next you will want to remove the two 6.35 mm screws using the J00 screwdriver.
      • Now you should be able to remove the green casing.
      Ask FixBot
    4. PS Vita Slim Display Replacement: step 8, image 1 of 3 PS Vita Slim Display Replacement: step 8, image 2 of 3 PS Vita Slim Display Replacement: step 8, image 3 of 3
      • Once the green casing has been removed you are now be able to see the button pads that need to be removed.
      • The D-pad and other such buttons can now be replaced or simply cleaned.
      Ask FixBot
    1. PS Vita Slim Display Replacement, Joystick: step 9, image 1 of 3 PS Vita Slim Display Replacement, Joystick: step 9, image 2 of 3 PS Vita Slim Display Replacement, Joystick: step 9, image 3 of 3
      • Starting with the left joystick.
      • There is a green casing holding in the joystick it will need to be removed to allow access .
      • There are 3 ribbons holding the section together. Remove them carefully.
      • Next unscrew the two screws holding down the casing. They will both still be 6.35 mm screws and will be able to be taken out by a J00 bit from the iFixit pro toolkit.
      • Now carefully left the metal piece holding down the green casing, it will be the last resistance. Lift out the green casing now.
      Ask FixBot
    2. PS Vita Slim Display Replacement: step 10, image 1 of 2 PS Vita Slim Display Replacement: step 10, image 2 of 2
      • Once the casing has been removed there will be one more screw to be removed. It will be a 6.35 mm screws that requires a J00 screwdriver from the iFixit pro toolkit.
      • Now simply and carefully take out the joystick out.
      • With the joystick taken out you can now do what is needed on the left joystick, or even replace it.
      Ask FixBot
    3. PS Vita Slim Display Replacement: step 11, image 1 of 3 PS Vita Slim Display Replacement: step 11, image 2 of 3 PS Vita Slim Display Replacement: step 11, image 3 of 3
      • Switching over to the right joystick.
      • There will be a green casing containing the joystick. First it must be removed.
      • Carefully remove the ribbons from the entire section.
      • Proceed to remove the two screws holding the casing down. They will be 6.35 mm screws and can be removed using a J00 bit.
      Ask FixBot
    4. PS Vita Slim Display Replacement: step 12, image 1 of 3 PS Vita Slim Display Replacement: step 12, image 2 of 3 PS Vita Slim Display Replacement: step 12, image 3 of 3
      • Once the casing is off, there will only be one more screw to take off. It will also be a 6.35 mm screw that uses the J00 bit from the iFixit pro toolkit.
      • Now simply remove the joystick from the device .
      • Once the joystick is removed you can do what is needed to the right joystick part, or even replace it if needed.
      Ask FixBot
    1. PS Vita Slim Display Replacement, Motherboard: step 13, image 1 of 2 PS Vita Slim Display Replacement, Motherboard: step 13, image 2 of 2
      • First you will want to remove the black casing holding the motherboard in.
      • Remove the two screws that are holding the casing down. These will be 6.35 mm screws that are to be removed using the J00 bit from the iFixit pro toolkit.
      • Once the screws are removed, carefully lift the case out of the system.
      Ask FixBot
    2. PS Vita Slim Display Replacement: step 14, image 1 of 2 PS Vita Slim Display Replacement: step 14, image 2 of 2
      • Next remove the two bottom 6.35 mm screws using the J00 bit from the iFixit pro toolkit.
      • Now you will be able to gently remove the bottom casing.
      Ask FixBot
    3. PS Vita Slim Display Replacement: step 15, image 1 of 3 PS Vita Slim Display Replacement: step 15, image 2 of 3 PS Vita Slim Display Replacement: step 15, image 3 of 3
      • Next you must remove the two ribbon cables connecting the motherboard to other hardware parts. Please be careful. The third ribbon on the bottom is a camera that also needs to be carefully removed.
      Ask FixBot
    4. PS Vita Slim Display Replacement: step 16, image 1 of 3 PS Vita Slim Display Replacement: step 16, image 2 of 3 PS Vita Slim Display Replacement: step 16, image 3 of 3
      • Now gently lift the motherboard up, as there will be a ribbon that still needs to be removed.
      • Carefully remove the last ribbon, from the hardware and not the motherboard.
      • The motherboard can be successfully removed.
      • Any repairs or replaces will be doable now.
      Ask FixBot
    1. PS Vita Slim Display Replacement, Display: step 17, image 1 of 1
      • The best way to replace the display is to replace the entire front.
      • So after following all prerequisite guides you will come to the blank slate that is left. Where nothing of the device will remain except for the front that contains the display itself.
      • From here you will need to acquire a new display, and using that display put the device back together.
      Ask FixBot
17 other people completed this guide.
5 Guide Comments
Any instructions on replacing the screen for a non-black case without replacing the whole front? It’s not the easy way but since they don’t sell the blue front with new screen, it’s the only way.
David - Reply Share
I couldn't find an answer anywhere else so here you go (3 years after you asked).
Take a heat gun or hair dryer and gently heat the border of the screen to soften the glue. Gently twist the front shell to help separate the screen.
Repeat as needed until a corner becomes raised/separated from the shell.
Take a rounded tip metal spudger (flat metal pry tool) and carefully slide it between the shell and the screen. Apply more heat and begin slowly working your way round the edge of the screen. I found it best to use two spudgers, one to twist and separate the screen, the other to slide as flat as possible under the screen.
The screen is recessed under a top glass cover which is where the glue is. I found if you push the spudger in between the cover and shell, it will separate the glue and stop it hits the screen.
Continue to slowly work your way round the edge of the screen until it comes off.
Dex Amundo - Reply Share
i didnt need to remove the motherboard etc, i just heated the screen from the front and unplugged it from the motherboard and it popped off easily. Saves time.
FG Console Repairs - Reply Share
Any leads my ps vita is working well touch is working everything working but no display at all? But i can touch and do stuff with imagining but jo display help
Tayyab - Reply Share
Hello! I just recently did the tear down, only to realize the ribbon cables (Slim Power Button and Flex Cable I thinks its called, image in Step 5) did not come with the new display screen I ordered. Is this normal? Are my next steps to order the individual part and figure out how to attachment to my new display? Any help/guidance would be appreciated.
Dom - Reply Share
Past 24 Hours: 31
Past 7 Days: 209
Past 30 Days: 975
All Time: 57,890
