PS Vita Slim Battery Replacement
Views: 51K
View statistics:
Past 24 Hours:
18
Past 7 Days:
213
Past 30 Days:
909
All Time:
50,888
Comments: 11
4 comments on steps, 7 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide's goal is to help the user to replace the battery of a PS Vita Slim if the battery is faulty or has some other kind of problem.
Parts
Tools
    1. PS Vita Slim Battery  Replacement, Back Panel: step 1, image 1 of 1
      • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
      • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
      • There are four screws on the back of the device, remove them as shown.
      Ask FixBot
    2. PS Vita Slim Battery  Replacement: step 2, image 1 of 2 PS Vita Slim Battery  Replacement: step 2, image 2 of 2
      • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
      • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
      Ask FixBot
    3. PS Vita Slim Battery  Replacement: step 3, image 1 of 3 PS Vita Slim Battery  Replacement: step 3, image 2 of 3 PS Vita Slim Battery  Replacement: step 3, image 3 of 3
      • The next step will require the opening tool.
      • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
      • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
      • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
      Ask FixBot
    4. PS Vita Slim Battery  Replacement: step 4, image 1 of 1
      • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
      Ask FixBot
    1. PS Vita Slim Battery  Replacement, Battery: step 5, image 1 of 3 PS Vita Slim Battery  Replacement, Battery: step 5, image 2 of 3 PS Vita Slim Battery  Replacement, Battery: step 5, image 3 of 3
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • The battery should be very visible at this point in the guide.
      • Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
      • Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
      • The battery isn't held in by anything, so it can fall out of the case if turned upside down.
      Ask FixBot
    2. PS Vita Slim Battery  Replacement: step 6, image 1 of 1
      • Now the battery is removable and the process should be complete. You should be free to do what is needed.
      Ask FixBot
14 other people completed this guide.
7 Guide Comments
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
Jack Wallis - Reply Share
The touchpad cable isn't able to be re-attached if you do this so your vita just ends up becoming permanently crippled. DO NOT FOLLOW THIS GUIDE.
polocatfan - Reply Share
@polocatfan yes it can? just needs some good technique
Darryl C - Reply Share
@squirrelmuncher can 100% confirm it's impossible. I tried for hours.
@polocatfan I just did the entire thing and removed the cable. All you have to do is make sure the latch is lifted up on the board. They should have included it in the instructions but you need to lift up the tiny brown latch so you can slide the cable back in then put the latch down. If the latch is up all it requires is steady hands and some good lighting
Justin - Reply Share
Past 24 Hours: 18
Past 7 Days: 213
Past 30 Days: 909
All Time: 50,888
