PRS Guitar Pickups Replacement
    1. PRS Guitar Pickups Replacement, Pickups: step 1, image 1 of 2 PRS Guitar Pickups Replacement, Pickups: step 1, image 2 of 2
      • Loosen all of the strings until they can be pulled out of the tuners.
      • Pull the strings through the bridge and out of the back side of the guitar.
      Ask FixBot
    2. PRS Guitar Pickups Replacement: step 2, image 1 of 2 PRS Guitar Pickups Replacement: step 2, image 2 of 2
      • Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
      Ask FixBot
    3. PRS Guitar Pickups Replacement: step 3, image 1 of 1
      • Take note of the wiring before desoldering the wires.
      • Begin desoldering the pickup wires.
      • Take care when soldering, as the tip is very hot.
      Ask FixBot
    4. PRS Guitar Pickups Replacement: step 4, image 1 of 2 PRS Guitar Pickups Replacement: step 4, image 2 of 2
      • Turn the guitar face up and unscrew both of the pickups.
      • Take the pickups out of the guitar.
      Ask FixBot
    5. PRS Guitar Pickups Replacement: step 5, image 1 of 2 PRS Guitar Pickups Replacement: step 5, image 2 of 2
      • Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
      • Run the new pickups back through the guitar with the wires guided through the back plate.
      • Carefully begin soldering the new pickup wires back together.
      Ask FixBot
    6. PRS Guitar Pickups Replacement: step 6, image 1 of 1
      • This is a good opportunity to clean the guitar.
      • Begin restringing the guitar with new strings of your preference.
      • Using a string/wire cutter and cut excess strings from tuners.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 57
All Time: 1,593
