Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
PHASE 3 FEEDER SENSOR
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
66
All Time:
273
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. PHASE 3 FEEDER SENSOR, Top Cover: step 1, image 1 of 2 PHASE 3 FEEDER SENSOR, Top Cover: step 1, image 2 of 2
      • Unplug the Laça tudo before you begin disassembling it.
      • Then, remove the 2 MAQ screws installed on the rear of the machine's top cover, and afterwards remove the 2 MAQ CHAT screws on the top using a 1/8 Phillips screwdriver. (Photo 1)
      • With the screws removed, take off the top cover. (Photo 2)
      Ask FixBot
    2. PHASE 3 FEEDER SENSOR: step 2, image 1 of 3 PHASE 3 FEEDER SENSOR: step 2, image 2 of 3 PHASE 3 FEEDER SENSOR: step 2, image 3 of 3
      • Now we will remove the rear cover; to do this, remove the 5 MAQ Phillips screws secured to the back of the machine.
      • After removing the screws, disconnect the mini-fan connector from the electronic board.
      • To do this, pull out the white 2-wire connector. (Photos 2 and 3)
      • When reassembling, follow the wiring diagram; each male connector has a specific color and must be connected to the female connector of the same color and number of wires.
      Ask FixBot
    3. PHASE 3 FEEDER SENSOR: step 3, image 1 of 1
      • After removing the cover screws and the Mini fan connector, remove the back cover. (Photo 1)
      Ask FixBot
    1. PHASE 3 FEEDER SENSOR, PHASE 3 FEEDER SENSOR: step 4, image 1 of 2 PHASE 3 FEEDER SENSOR, PHASE 3 FEEDER SENSOR: step 4, image 2 of 2
      • The next step is to disconnect the 3-wire White connector of the Ribbon power sensor on the power board. (Photo 1)
      • Do not touch the Electronic Board; some components are very sensitive, and by touching the board, we may transfer static electricity to it, damaging the components.
      Ask FixBot
    2. PHASE 3 FEEDER SENSOR: step 5, image 1 of 2 PHASE 3 FEEDER SENSOR: step 5, image 2 of 2
      • With the connector disconnected, we can release the power sensor.
      • To do this, open the front cover, and then release the 2 machine screws that secure the sensor using a Phillips screwdriver. (Photo 1)
      • With the sensor released, simply remove it from the machine.
      • When reassembling, follow the wiring diagram.
      Ask FixBot
Follow these instructions in reverse order to reassemble your device.
Author
with
Lacito
6,169 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 66
All Time: 273
