PDP Victrix Pro BFG Headphone Jack Replacement
  1. PDP Victrix Pro BFG Headphone Jack Replacement, Headphone Jack: step 1, image 1 of 1
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
    Ask FixBot
  2. PDP Victrix Pro BFG Headphone Jack Replacement: step 2, image 1 of 1
    • Remove the two screws from the module compartments.
    Ask FixBot
  3. PDP Victrix Pro BFG Headphone Jack Replacement: step 3, image 1 of 2 PDP Victrix Pro BFG Headphone Jack Replacement: step 3, image 2 of 2
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using the screwdriver tool with a head of around 2 mm, remove the screws located in the bottom outside corners.
    Ask FixBot
  4. PDP Victrix Pro BFG Headphone Jack Replacement: step 4, image 1 of 1
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same screwdriver head setting from the previous step, remove the screw.
    Ask FixBot
  5. PDP Victrix Pro BFG Headphone Jack Replacement: step 5, image 1 of 1
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
    Ask FixBot
  6. PDP Victrix Pro BFG Headphone Jack Replacement: step 6, image 1 of 1
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
    Ask FixBot
  7. PDP Victrix Pro BFG Headphone Jack Replacement: step 7, image 1 of 1
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
    Ask FixBot
  8. PDP Victrix Pro BFG Headphone Jack Replacement: step 8, image 1 of 1
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
    Ask FixBot
  9. PDP Victrix Pro BFG Headphone Jack Replacement: step 9, image 1 of 1
    • Using a soldering iron, desolder the headphone jack and resolder a new one in its place.
    Ask FixBot
Ryan Brise
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 69
All Time: 936
