Up to 20% off select tools
PDP Rematch Joystick Cover Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
116
All Time:
1,533
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
The Joystick is an essential part of the PDP Rematch controller. Over time, the joysticks may stop working due to wear and tear. If they need replacing, you can buy them separately.
    1. PDP Rematch Joystick Cover Replacement, Faceplate: step 1, image 1 of 2 PDP Rematch Joystick Cover Replacement, Faceplate: step 1, image 2 of 2
      • Grip one side of the controller firmly.
      • Insert an opening pick into the crease between the faceplate and the body of the controller.
      • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
      • Carefully move the picks along the controller's crease line until you hear a popping sound.
      • Gently lift off the faceplate by hand.
      Ask FixBot
    2. PDP Rematch Joystick Cover Replacement: step 2, image 1 of 2 PDP Rematch Joystick Cover Replacement: step 2, image 2 of 2
      • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
      • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
      Ask FixBot
    3. PDP Rematch Joystick Cover Replacement: step 3, image 1 of 2 PDP Rematch Joystick Cover Replacement: step 3, image 2 of 2
      • Gently lift off the hard cover with your hand; it should not need much force.
      Ask FixBot
    1. PDP Rematch Joystick Cover Replacement, Joystick Cover: step 4, image 1 of 1
      • The action buttons and silicone pad are loose and may fall out of the controller.
      Ask FixBot
    2. PDP Rematch Joystick Cover Replacement: step 5, image 1 of 2 PDP Rematch Joystick Cover Replacement: step 5, image 2 of 2
      • Gently rotate or twist the joystick(s) you want to replace.
      • Apply some force and pull upward towards you.
      • You will know it is released when you hear a popping sound.
      • Place your new joystick and push it downwards; you will hear a popping sound again.
      Ask FixBot
Author
with
Amina Begum
282 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 116
All Time: 1,533
