Up to 20% off select tools
PDP Rematch Faceplate Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
11
Past 30 Days:
92
All Time:
1,129
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
If your faceplate is cracked or broken, this guide will help you replace the faceplate for the PDP Rematch controller (model 500-134-1).
The faceplate serves as a protective cover for the controller.
Before beginning, make sure to disconnect the controller's wire from any external power source.
    1. PDP Rematch Faceplate Replacement, Faceplate: step 1, image 1 of 2 PDP Rematch Faceplate Replacement, Faceplate: step 1, image 2 of 2
      • Grip one side of the controller firmly.
      • Insert an opening pick into the crease between the faceplate and the body of the controller.
      • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
      • Carefully move the picks along the controller's crease line until you hear a popping sound.
      • Gently lift off the faceplate by hand.
      Ask FixBot
    2. PDP Rematch Faceplate Replacement: step 2, image 1 of 2 PDP Rematch Faceplate Replacement: step 2, image 2 of 2
      • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
      • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
      Ask FixBot
    3. PDP Rematch Faceplate Replacement: step 3, image 1 of 2 PDP Rematch Faceplate Replacement: step 3, image 2 of 2
      • Gently lift off the hard cover with your hand; it should not need much force.
      Ask FixBot
Author
with
Amina Begum
282 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 92
All Time: 1,129
