Up to 20% off select tools
PDP Rematch Advanced Triggers Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
104
All Time:
994
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Triggers may need to be replaced if they become worn out or too sensitive. If you need to replace the triggers on your PDP Rematch Advanced controller, follow this guide. The triggers can be taken out by unscrewing them from the motherboard.
    1. PDP Rematch Advanced Triggers Replacement, Triggers: step 1, image 1 of 2 PDP Rematch Advanced Triggers Replacement, Triggers: step 1, image 2 of 2
      • Orient the controller so the back side is facing you.
      • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
      Ask FixBot
    2. PDP Rematch Advanced Triggers Replacement: step 2, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 2, image 2 of 2
      • Pull apart the controller's front and back shells with moderate force.
      • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
      Ask FixBot
    3. PDP Rematch Advanced Triggers Replacement: step 3, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 5 mm screws that secure the motherboard.
      Ask FixBot
    4. PDP Rematch Advanced Triggers Replacement: step 4, image 1 of 1
      • Remove the motherboard from the back shell using moderate force.
      Ask FixBot
    5. PDP Rematch Advanced Triggers Replacement: step 5, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 5, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two trigger springs from the motherboard.
      Ask FixBot
    6. PDP Rematch Advanced Triggers Replacement: step 6, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 6, image 2 of 2
      • Use a hair dryer to remove the trigger from the motherboard.
      Ask FixBot
Author
with
Kevin Crawford
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 104
All Time: 994
