Tools
Introduction
Go to step 1 ↓If the triggers require extra force or do not return back to their original position the trigger springs need to be removed. This guide will show how to separate the controller and remove both trigger spring on the PDP Rematch Controller.
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
