Up to 20% off select tools
PDP Rematch Advanced Shoulder Buttons Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
86
All Time:
1,002
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The shoulder buttons on your PDP Rematch Advanced should be replaced if they are getting stuck or damaged. If you need to replace a shoulder button, take out the front shell with this guide. The shoulder buttons are attached to the top of the front shell.
The shoulder buttons can be removed by taking out the shoulder button frame, attached to the back of the front shell.
    1. PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: step 1, image 1 of 3 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: step 1, image 2 of 3 PDP Rematch Advanced Shoulder Buttons Replacement, Front Housing Shell: step 1, image 3 of 3
      • Orient the controller so the back side is facing you.
      • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
      Ask FixBot
    2. PDP Rematch Advanced Shoulder Buttons Replacement: step 2, image 1 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 2, image 2 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 2, image 3 of 3
      • Pull apart the controller's front and back shells with moderate force.
      • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
      Ask FixBot
    3. PDP Rematch Advanced Shoulder Buttons Replacement: step 3, image 1 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 3, image 2 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 3, image 3 of 3
      • Peel the rubber piece off the back of the face buttons.
      Ask FixBot
    4. PDP Rematch Advanced Shoulder Buttons Replacement: step 4, image 1 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 4, image 2 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 4, image 3 of 3
      • Push all the face buttons out from the front of the shell.
      Ask FixBot
    5. PDP Rematch Advanced Shoulder Buttons Replacement: step 5, image 1 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 5, image 2 of 3 PDP Rematch Advanced Shoulder Buttons Replacement: step 5, image 3 of 3
      • Put two fingers behind the bumpers and push upwards to remove them.
      Ask FixBot
    1. PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: step 6, image 1 of 3 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: step 6, image 2 of 3 PDP Rematch Advanced Shoulder Buttons Replacement, Shoulder Buttons: step 6, image 3 of 3
      • Push down on the trigger's long paddle.
      • Carefully twist the bumper out to remove it from the bumper frame.
      Ask FixBot
Author
with
Angel Velasquez
369 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 86
All Time: 1,002
