Tools
Introduction
Go to step 1 ↓The front housing shell should be replaced on your PDP Rematch Advanced controller if it is cracked or damaged. If you need to replace the front housing shell, separate the front and back shell of the controller with this guide.
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
