Up to 20% off select tools
PDP Rematch Advanced Back Shell Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
99
All Time:
831
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The back shell of your PDP Rematch Advanced should be replaced if it's damaged or if you want to swap it out for a different color shell. If you need to replace the back shell, take out the motherboard with this guide.
    1. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: step 1, image 1 of 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: step 1, image 2 of 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: step 1, image 3 of 3
      • Orient the controller so the back side is facing you.
      • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
      Ask FixBot
    2. PDP Rematch Advanced Back Shell Replacement: step 2, image 1 of 3 PDP Rematch Advanced Back Shell Replacement: step 2, image 2 of 3 PDP Rematch Advanced Back Shell Replacement: step 2, image 3 of 3
      • Pull apart the controller's front and back shells with moderate force.
      • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
      Ask FixBot
    3. PDP Rematch Advanced Back Shell Replacement: step 3, image 1 of 2 PDP Rematch Advanced Back Shell Replacement: step 3, image 2 of 2
      • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
      Ask FixBot
    1. PDP Rematch Advanced Back Shell Replacement, Back Shell: step 4, image 1 of 2 PDP Rematch Advanced Back Shell Replacement, Back Shell: step 4, image 2 of 2
      • Grab the motor and pull away from the back shell. Repeat for both motors.
      Ask FixBot
    2. PDP Rematch Advanced Back Shell Replacement: step 5, image 1 of 2 PDP Rematch Advanced Back Shell Replacement: step 5, image 2 of 2
      • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
      Ask FixBot
    3. PDP Rematch Advanced Back Shell Replacement: step 6, image 1 of 3 PDP Rematch Advanced Back Shell Replacement: step 6, image 2 of 3 PDP Rematch Advanced Back Shell Replacement: step 6, image 3 of 3
      • Remove the motherboard from the back shell using moderate force.
      Ask FixBot
Author
with
Angel Velasquez
369 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 99
All Time: 831
