Up to 20% off select tools
PDP Rematch Advanced Action Buttons Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
80
All Time:
1,637
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 6 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The action buttons should be replaced on your PDP Rematch Advanced controller if they take more effort to press down. If you need to replace any of the action buttons, separate the front housing shell from the motherboard with this guide.
    1. PDP Rematch Advanced Action Buttons Replacement, Action Buttons: step 1, image 1 of 3 PDP Rematch Advanced Action Buttons Replacement, Action Buttons: step 1, image 2 of 3 PDP Rematch Advanced Action Buttons Replacement, Action Buttons: step 1, image 3 of 3
      • Orient the controller so the back side is facing you.
      • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
      Ask FixBot
    2. PDP Rematch Advanced Action Buttons Replacement: step 2, image 1 of 3 PDP Rematch Advanced Action Buttons Replacement: step 2, image 2 of 3 PDP Rematch Advanced Action Buttons Replacement: step 2, image 3 of 3
      • Pull apart the controller's front and back shells with moderate force.
      • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
      Ask FixBot
    3. PDP Rematch Advanced Action Buttons Replacement: step 3, image 1 of 3 PDP Rematch Advanced Action Buttons Replacement: step 3, image 2 of 3 PDP Rematch Advanced Action Buttons Replacement: step 3, image 3 of 3
      • Peel the rubber gasket off the back of the action buttons.
      Ask FixBot
    4. PDP Rematch Advanced Action Buttons Replacement: step 4, image 1 of 3 PDP Rematch Advanced Action Buttons Replacement: step 4, image 2 of 3 PDP Rematch Advanced Action Buttons Replacement: step 4, image 3 of 3
      • Push all the action buttons out from the front of the shell.
      Ask FixBot
Author
with
Collin Lawe
462 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 80
All Time: 1,637
