Up to 20% off select tools
PDP Rematch Action Buttons Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
123
All Time:
1,315
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your action buttons (the buttons labeled X, A, B, Y) are not working, not performing the correct action when pressed, or taking longer to pop back up, use this guide to replace the action buttons for the PDP Rematch Controller, model number 500-134-1.
The action buttons allow a user to perform different actions in video games.
Before using this guide, check for dirt or other debris buildup underneath the buttons. You can typically clean them using a Q-tip or a cotton pad with some rubbing alcohol.
Also, make sure the device is disconnected from any external power source.
    1. PDP Rematch Action Buttons Replacement, Faceplate: step 1, image 1 of 2 PDP Rematch Action Buttons Replacement, Faceplate: step 1, image 2 of 2
      • Grip one side of the controller firmly.
      • Insert an opening pick into the crease between the faceplate and the body of the controller.
      • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
      • Carefully move the picks along the controller's crease line until you hear a popping sound.
      • Gently lift off the faceplate by hand.
      Ask FixBot
    2. PDP Rematch Action Buttons Replacement: step 2, image 1 of 2 PDP Rematch Action Buttons Replacement: step 2, image 2 of 2
      • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
      • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
      Ask FixBot
    3. PDP Rematch Action Buttons Replacement: step 3, image 1 of 2 PDP Rematch Action Buttons Replacement: step 3, image 2 of 2
      • Gently lift off the hard cover with your hand; it should not need much force.
      Ask FixBot
    1. PDP Rematch Action Buttons Replacement, Action Buttons: step 4, image 1 of 1
      • Optional: Use a cotton pad or cotton swab with some alcohol to gently clean any debris.
      • These buttons are not connected to the device and will fall out, so be careful.
      Ask FixBot
    2. PDP Rematch Action Buttons Replacement: step 5, image 1 of 3 PDP Rematch Action Buttons Replacement: step 5, image 2 of 3 PDP Rematch Action Buttons Replacement: step 5, image 3 of 3
      • Carefully remove the buttons from the device and set them aside.
      • From here, you can do a deeper clean, or replace them.
      • The clear plate will not sit right or click into place if the buttons are not aligned straight.
      Ask FixBot
Author
with
Katie Barnes
93 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 123
All Time: 1,315
