PDP Afterglow Wired Xbox 360 Controller LEDs Replacement
  1. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: step 1, image 1 of 2 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: step 1, image 2 of 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
    Ask FixBot
  2. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
    Ask FixBot
  3. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: step 3, image 1 of 1
    • Remove the top cover from the bottom and place next to each other.
    Ask FixBot
  4. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: step 4, image 1 of 2 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: step 4, image 2 of 2
    • Remove the logic board from the controller casing by lifting up and pulling out.
    Ask FixBot
  5. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: step 5, image 1 of 1
    • Locate the LED (s) that needs to be replaced.
    • Once the LED has been located, flip the logic board to the other side and locate the pins associated with the LED that needs to be replaced.
    Ask FixBot
  6. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: step 6, image 1 of 1
    • Desolder the LED from the logic board.
    • The soldering iron is very hot and can harm you or the device if used improperly.
    Ask FixBot
Joi Officer
313 Reputation
2 Guides authored
IUPUI, Team 3-1, Harley Fall 2015 Member of IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 2,505
