PDP Afterglow Wired Xbox 360 Controller Cable Replacement
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: step 1, image 1 of 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: step 1, image 2 of 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
    Ask FixBot
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
    Ask FixBot
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: step 3, image 1 of 1
    • Remove the top cover from the bottom and place next to each other.
    Ask FixBot
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: step 4, image 1 of 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: step 4, image 2 of 2
    • Remove the logic board by lifting up on the logic board and pulling out.
    Ask FixBot
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: step 5, image 1 of 1
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
    Ask FixBot
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: step 6, image 1 of 1
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
    Ask FixBot
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: step 7, image 1 of 1
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
    Ask FixBot
7 other people completed this guide.
Jayson Norcross
344 Reputation
1 Guide authored
IUPUI, Team 3-1, Harley Fall 2015 Member of IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Members
5 Guides authored
4 Guide Comments
where can I find a replacement cable to perform this precedure with?
Aaron English - Reply Share
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 - Reply Share
Android cable
Wayne - Reply Share
U can use a old Android cable
Wayne - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 91
All Time: 8,622
