PDP Afterglow Fener Wireless Dongle USB Wire Repair
  1. PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 1, image 1 of 3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 1, image 2 of 3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair, PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 1, image 3 of 3
    • First, remove the heat shrink from the new USB.
    • Then remove the signal shield protection from the new USB.
    • Next, cut the 4 wire ends that are now protruding from the end of the USB.
    Ask FixBot
  2. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 2, image 1 of 3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 2, image 2 of 3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 2, image 3 of 3
    • Then do the same process as above, for the USB wire coming out of the dongle itself.
    • Bend the wire ends so that they form hook shapes.
    • Connect the two hooks together.
    Ask FixBot
  3. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 3, image 1 of 3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 3, image 2 of 3 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 3, image 3 of 3
    • Once hooked, twist the two wires together to keep a strong connection.
    • Use a helping hand or other platform to perform the soldering.
    • Now solder the two wires together. Be careful to avoid melting the heat shrink otherwise it may get onto the copper wires.
    Ask FixBot
  4. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 4, image 1 of 2 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 4, image 2 of 2
    • Next you can use a heat gun to melt the heat shrinks together for maximum wire protection.
    Ask FixBot
  5. PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 5, image 1 of 2 PDP Afterglow Fener Wireless  Dongle USB Wire Repair: step 5, image 2 of 2
    • Finally, you can cover the whole thing with either a large heat shrink, or some electrical tape.
    Ask FixBot
This guide does not require reassembly, as the guide itself is re-attaching the USB.
Thomas Williams
512 Reputation
4 Guides authored
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 2,072
