Up to 20% off select tools
PC Laptop matherboard Replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
39
Past 30 Days:
183
All Time:
284
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Laptop Motherboard Replacement Guide
This guide explains how to replace a laptop motherboard safely and correctly.
Before starting, make sure you have the necessary tools, a compatible replacement motherboard, and a clean workspace.
Tools and precautions:
  • Precision screwdriver set
  • Plastic opening tool
  • Anti-static wrist strap
  • Thermal paste, if required
Important safety precautions:
  1. Shut down the laptop and disconnect the charger.
  2. Remove the battery if it is removable, or disconnect the internal battery before handling components.
  3. Protect sensitive electronics from electrostatic discharge (ESD).
  4. Keep screws organized and take photos of cable connections before disconnecting them.
The exact replacement procedure depends on the laptop model. Always consult the manufacturer's service manual before removing the motherboard.
Tignool Tech and consulting
31 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 39
Past 30 Days: 183
All Time: 284
