PBB-272C Powered Proto Bread Board Use
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
52
All Time:
272
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Place the proto board in your work area where you can easily access it.
Video Overview
    1. PBB-272C Powered Proto Bread Board Use, PBB-272C Powered Proto Bread Board Use: step 1, image 1 of 3 PBB-272C Powered Proto Bread Board Use, PBB-272C Powered Proto Bread Board Use: step 1, image 2 of 3 PBB-272C Powered Proto Bread Board Use, PBB-272C Powered Proto Bread Board Use: step 1, image 3 of 3
      • (MAKE SURE NO POWER IS APPLIED TO BOARD WHEN BUILDING CIRCUIT)
      • Add your components like IC chips, microcontroller etc to the board.
      • Add wires as needed based on your schematic.
      • Adjust power supplies as needed. Connect power to circuit. Test your circuit
      • Remove your components and plan for next build.
      Ask FixBot
Breadboarding is an easy way to build and test electronic circuits.
rickwag
1,906 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 272
