Up to 20% off select tools
P775DM3 Replacement of fans
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
98
All Time:
931
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to replace the cooling fans on a why! P775DM3 laptop.
    1. P775DM3 Replacement of fans, Battery: step 1, image 1 of 2 P775DM3 Replacement of fans, Battery: step 1, image 2 of 2
      • Unlock the lock circled in red.
      Ask FixBot
    2. P775DM3 Replacement of fans: step 2, image 1 of 3 P775DM3 Replacement of fans: step 2, image 2 of 3 P775DM3 Replacement of fans: step 2, image 3 of 3
      • Lift the battery while unlocking the lock circled in red.
      Ask FixBot
    1. P775DM3 Replacement of fans, Access to major components: step 3, image 1 of 2 P775DM3 Replacement of fans, Access to major components: step 3, image 2 of 2
      • Unscrew the five screws circled in red.
      Ask FixBot
    2. P775DM3 Replacement of fans: step 4, image 1 of 2 P775DM3 Replacement of fans: step 4, image 2 of 2
      • Slide the plate in the direction of the red arrow.
      Ask FixBot
    3. P775DM3 Replacement of fans: step 5, image 1 of 2 P775DM3 Replacement of fans: step 5, image 2 of 2
      • Lift the cover.
      Ask FixBot
    1. P775DM3 Replacement of fans, Cooler: step 6, image 1 of 3 P775DM3 Replacement of fans, Cooler: step 6, image 2 of 3 P775DM3 Replacement of fans, Cooler: step 6, image 3 of 3
      • Unscrew the four large screws circled in green.
      • Unscrew the five small screws circled in red.
      • Lift the cooler with the two tabs circled in blue.
      Ask FixBot
    1. P775DM3 Replacement of fans, GPU: step 7, image 1 of 2 P775DM3 Replacement of fans, GPU: step 7, image 2 of 2
      • Unscrew the two screws circled in red.
      Ask FixBot
    2. P775DM3 Replacement of fans: step 8, image 1 of 3 P775DM3 Replacement of fans: step 8, image 2 of 3 P775DM3 Replacement of fans: step 8, image 3 of 3
      • Lift the card to allow access to the red circled connector.
      • Disconnect the red circled connector.
      Ask FixBot
    3. P775DM3 Replacement of fans: step 9, image 1 of 3 P775DM3 Replacement of fans: step 9, image 2 of 3 P775DM3 Replacement of fans: step 9, image 3 of 3
      • Pull the card in the direction of the red arrow.
      Ask FixBot
    1. P775DM3 Replacement of fans, Fans: step 10, image 1 of 3 P775DM3 Replacement of fans, Fans: step 10, image 2 of 3 P775DM3 Replacement of fans, Fans: step 10, image 3 of 3
      • Unscrew the three screws circled in red.
      • Disconnect the framed connector in red.
      Ask FixBot
    2. P775DM3 Replacement of fans: step 11, image 1 of 1
      • Remove the fan.
      Ask FixBot
    3. P775DM3 Replacement of fans: step 12, image 1 of 3 P775DM3 Replacement of fans: step 12, image 2 of 3 P775DM3 Replacement of fans: step 12, image 3 of 3
      Ask FixBot
    4. P775DM3 Replacement of fans: step 13, image 1 of 1
      • Lift the fan.
      Ask FixBot
To reassemble your device follow the following instructions in reverse order
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Felice Suglia
33,655 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 98
All Time: 931
