Up to 20% off select tools
P775DM3 Motherboard replacement
Views: 3K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
125
All Time:
3,045
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to replace the motherboard in a P775DM3 laptop.
    1. P775DM3 Motherboard replacement, Battery: step 1, image 1 of 2 P775DM3 Motherboard replacement, Battery: step 1, image 2 of 2
      • Unlock the lock circled in red.
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 2, image 1 of 3 P775DM3 Motherboard replacement: step 2, image 2 of 3 P775DM3 Motherboard replacement: step 2, image 3 of 3
      • Lift the battery while unlocking the lock circled in red.
      Ask FixBot
    1. P775DM3 Motherboard replacement, Disk access: step 3, image 1 of 1
      • Unscrew the two screws circled in red.
      • Slide the plate in the direction of the arrow.
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 4, image 1 of 2 P775DM3 Motherboard replacement: step 4, image 2 of 2
      • Lift the plate.
      Ask FixBot
    1. P775DM3 Motherboard replacement, Hard Disk Drive: step 5, image 1 of 3 P775DM3 Motherboard replacement, Hard Disk Drive: step 5, image 2 of 3 P775DM3 Motherboard replacement, Hard Disk Drive: step 5, image 3 of 3
      • Unscrew the screw circled in red.
      • Lift the disk using the tab circled in green.
      • Remove the disk in the direction of the arrow.
      Ask FixBot
    1. P775DM3 Motherboard replacement, M.2 SSD: step 6, image 1 of 2 P775DM3 Motherboard replacement, M.2 SSD: step 6, image 2 of 2
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 7, image 1 of 2 P775DM3 Motherboard replacement: step 7, image 2 of 2
      • Pull the SSD in the direction of the red arrow.
      Ask FixBot
    1. P775DM3 Motherboard replacement, Access to major components: step 8, image 1 of 2 P775DM3 Motherboard replacement, Access to major components: step 8, image 2 of 2
      • Unscrew the five screws circled in red.
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 9, image 1 of 2 P775DM3 Motherboard replacement: step 9, image 2 of 2
      • Slide the plate in the direction of the red arrow.
      Ask FixBot
    3. P775DM3 Motherboard replacement: step 10, image 1 of 2 P775DM3 Motherboard replacement: step 10, image 2 of 2
      • Lift the cover.
      Ask FixBot
    1. P775DM3 Motherboard replacement, Keyboard: step 11, image 1 of 2 P775DM3 Motherboard replacement, Keyboard: step 11, image 2 of 2
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 12, image 1 of 3 P775DM3 Motherboard replacement: step 12, image 2 of 3 P775DM3 Motherboard replacement: step 12, image 3 of 3
      • Press a paper clip in the three places marked in red
      • Lift the keyboard and feel free to put some strength
      Ask FixBot
    3. P775DM3 Motherboard replacement: step 13, image 1 of 2 P775DM3 Motherboard replacement: step 13, image 2 of 2
      • Disconnect the three framed connectors in red
      Ask FixBot
    4. P775DM3 Motherboard replacement: step 14, image 1 of 2 P775DM3 Motherboard replacement: step 14, image 2 of 2
      • Pull the white drawer in the direction of the arrow to unlock the connector
      • Disconnect the red circled connector
      Ask FixBot
    5. P775DM3 Motherboard replacement: step 15, image 1 of 2 P775DM3 Motherboard replacement: step 15, image 2 of 2
      • Pull the black drawer in the direction of the arrow to unlock the connector
      Ask FixBot
    6. P775DM3 Motherboard replacement: step 16, image 1 of 3 P775DM3 Motherboard replacement: step 16, image 2 of 3 P775DM3 Motherboard replacement: step 16, image 3 of 3
      • Lift the flap that holds the connector circled in red
      • Remove the keyboard
      Ask FixBot
    1. P775DM3 Motherboard replacement, RAM: step 17, image 1 of 3 P775DM3 Motherboard replacement, RAM: step 17, image 2 of 3 P775DM3 Motherboard replacement, RAM: step 17, image 3 of 3
      • Spread the two clips in red.
      • Remove the RAM card.
      Ask FixBot
    1. P775DM3 Motherboard replacement, BIOS Battery: step 18, image 1 of 3 P775DM3 Motherboard replacement, BIOS Battery: step 18, image 2 of 3 P775DM3 Motherboard replacement, BIOS Battery: step 18, image 3 of 3
      • Disconnect the connector circled in red.
      • Remove the battery.
      Ask FixBot
    1. P775DM3 Motherboard replacement, WLAN card removal: step 19, image 1 of 3 P775DM3 Motherboard replacement, WLAN card removal: step 19, image 2 of 3 P775DM3 Motherboard replacement, WLAN card removal: step 19, image 3 of 3
      • Disconnect the two connectors circled in green.
      • Remove the WLAN card.
      Ask FixBot
    1. P775DM3 Motherboard replacement, Cooler: step 20, image 1 of 3 P775DM3 Motherboard replacement, Cooler: step 20, image 2 of 3 P775DM3 Motherboard replacement, Cooler: step 20, image 3 of 3
      • Unscrew the four large screws circled in green.
      • Unscrew the five small screws circled in red.
      • Lift the cooler with the two tabs circled in blue.
      Ask FixBot
    1. P775DM3 Motherboard replacement, CPU: step 21, image 1 of 3 P775DM3 Motherboard replacement, CPU: step 21, image 2 of 3 P775DM3 Motherboard replacement, CPU: step 21, image 3 of 3
      • Pull the lever circled in red in the direction of the red arrow while pressing on it.
      • Don't touch the underside of the processor, and pick it up by the sides.
      Ask FixBot
    1. P775DM3 Motherboard replacement, GPU: step 22, image 1 of 2 P775DM3 Motherboard replacement, GPU: step 22, image 2 of 2
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 23, image 1 of 3 P775DM3 Motherboard replacement: step 23, image 2 of 3 P775DM3 Motherboard replacement: step 23, image 3 of 3
      • Lift the card to allow access to the red circled connector.
      • Disconnect the red circled connector.
      Ask FixBot
    3. P775DM3 Motherboard replacement: step 24, image 1 of 3 P775DM3 Motherboard replacement: step 24, image 2 of 3 P775DM3 Motherboard replacement: step 24, image 3 of 3
      • Pull the card in the direction of the red arrow.
      Ask FixBot
    1. P775DM3 Motherboard replacement, Fans: step 25, image 1 of 3 P775DM3 Motherboard replacement, Fans: step 25, image 2 of 3 P775DM3 Motherboard replacement, Fans: step 25, image 3 of 3
      • Unscrew the three screws circled in red.
      • Disconnect the framed connector in red.
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 26, image 1 of 1
      • Remove the fan.
      Ask FixBot
    3. P775DM3 Motherboard replacement: step 27, image 1 of 3 P775DM3 Motherboard replacement: step 27, image 2 of 3 P775DM3 Motherboard replacement: step 27, image 3 of 3
      Ask FixBot
    4. P775DM3 Motherboard replacement: step 28, image 1 of 1
      • Lift the fan.
      Ask FixBot
    1. P775DM3 Motherboard replacement, Motherboard: step 29, image 1 of 3 P775DM3 Motherboard replacement, Motherboard: step 29, image 2 of 3 P775DM3 Motherboard replacement, Motherboard: step 29, image 3 of 3
      • Lift the flap that holds the two connectors framed in red.
      • Disconnect the two framed connectors in red.
      Ask FixBot
    2. P775DM3 Motherboard replacement: step 30, image 1 of 2 P775DM3 Motherboard replacement: step 30, image 2 of 2
      • Disconnect the box connector in green.
      Ask FixBot
    3. P775DM3 Motherboard replacement: step 31, image 1 of 2 P775DM3 Motherboard replacement: step 31, image 2 of 2
      • Unscrew the twenty screws circled in red.
      • Unclip the edge of the case at the two places framed in green.
      Ask FixBot
    4. P775DM3 Motherboard replacement: step 32, image 1 of 3 P775DM3 Motherboard replacement: step 32, image 2 of 3 P775DM3 Motherboard replacement: step 32, image 3 of 3
      • Remove the top of the case.
      Ask FixBot
    5. P775DM3 Motherboard replacement: step 33, image 1 of 3 P775DM3 Motherboard replacement: step 33, image 2 of 3 P775DM3 Motherboard replacement: step 33, image 3 of 3
      • Remove the framed card in blue.
      • Remove the framed card in orange.
      Ask FixBot
    6. P775DM3 Motherboard replacement: step 34, image 1 of 2 P775DM3 Motherboard replacement: step 34, image 2 of 2
      • Disconnect the two framed connectors in green.
      Ask FixBot
    7. P775DM3 Motherboard replacement: step 35, image 1 of 2 P775DM3 Motherboard replacement: step 35, image 2 of 2
      Ask FixBot
    8. P775DM3 Motherboard replacement: step 36, image 1 of 2 P775DM3 Motherboard replacement: step 36, image 2 of 2
      • Remove the motherboard.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Felice Suglia
33,655 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 125
All Time: 3,045
