Ozeri Pronto ZK14-S Wire Replacement
Views: 5.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
85
All Time:
5,711
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide explains how to remove the wires from the weight sensor each of the motherboards inside the Ozeri Pronto ZK14-S in separate steps. Assistance may be necessary if you do not feel confident about using the iOpener.
Tools
    1. Ozeri Pronto ZK14-S Wire Replacement, Panel Removal: step 1, image 1 of 2 Ozeri Pronto ZK14-S Wire Replacement, Panel Removal: step 1, image 2 of 2
      • Twist the plastic plate slowly to the left to pull it away.
      Ask FixBot
    2. Ozeri Pronto ZK14-S Wire Replacement: step 2, image 1 of 1
      • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
      • The sticker does not need to be completely removed.
      Ask FixBot
    3. Ozeri Pronto ZK14-S Wire Replacement: step 3, image 1 of 1
      • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
      Ask FixBot
    4. Ozeri Pronto ZK14-S Wire Replacement: step 4, image 1 of 2 Ozeri Pronto ZK14-S Wire Replacement: step 4, image 2 of 2
      • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
      Ask FixBot
    5. Ozeri Pronto ZK14-S Wire Replacement: step 5, image 1 of 2 Ozeri Pronto ZK14-S Wire Replacement: step 5, image 2 of 2
      • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
      Ask FixBot
    6. Ozeri Pronto ZK14-S Wire Replacement: step 6, image 1 of 1
      • Turn the device over so the back panel is facing up.
      Ask FixBot
    7. Ozeri Pronto ZK14-S Wire Replacement: step 7, image 1 of 1
      • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
      Ask FixBot
    8. Ozeri Pronto ZK14-S Wire Replacement: step 8, image 1 of 1
      • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
      Ask FixBot
    9. Ozeri Pronto ZK14-S Wire Replacement: step 9, image 1 of 2 Ozeri Pronto ZK14-S Wire Replacement: step 9, image 2 of 2
      • Pry apart the two panels to separate them from each other.
      • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
      • Be careful when separating the panels to avoid damaging the wires they are connected by.
      Ask FixBot
    1. Ozeri Pronto ZK14-S Wire Replacement, Wire: step 10, image 1 of 2 Ozeri Pronto ZK14-S Wire Replacement, Wire: step 10, image 2 of 2
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screws on the back of the center LCD motherboard.
      Ask FixBot
    2. Ozeri Pronto ZK14-S Wire Replacement: step 11, image 1 of 1
      • Stand the center motherboard up.
      • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
      Ask FixBot
    3. Ozeri Pronto ZK14-S Wire Replacement: step 12, image 1 of 1
      • Desolder the post the damaged wire is attached to on the motherboard.
      • Use caution when handling the soldering iron since it can get very hot.
      Ask FixBot
    4. Ozeri Pronto ZK14-S Wire Replacement: step 13, image 1 of 1
      • Using the iOpener, warm the glue on the weight sensor the other end of the damaged wire is attached to.
      • Use caution when handling the iOpener since it can get very hot.
      • Refer to the following guide for detailed instructions on how to use the iOpener: iOpener (Legacy) Instructions
      Ask FixBot
    5. Ozeri Pronto ZK14-S Wire Replacement: step 14, image 1 of 1
      • Using the nylon or metal spudger, detach the end of the damaged wire from the weight sensor.
      • Repeat steps 13 and 14 to remove the end of a damaged wire from the other two motherboards.
      Ask FixBot
Oneika White
726 Reputation
4 Guides authored
USF Tampa, Team 1-4, Leahy Fall 2015 Member of USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 Members
60 Guides authored
1 Guide Comment
Why are you doing this repair? My balance simply stopped turning on. Is this the repair process to fix my balance?
Wacy - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 85
All Time: 5,711
