Ozeri Pronto ZK14-S LCD Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
96
All Time:
1,291
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide explains how to expose the LCD screen of the Ozeri Pronto ZK14-S. The detachment of the LCD motherboard is necessary to reveal the actual screen.
    1. Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: step 1, image 1 of 2 Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: step 1, image 2 of 2
      • Twist the plastic plate slowly to the left to pull it away.
      Ask FixBot
    2. Ozeri Pronto ZK14-S LCD Replacement: step 2, image 1 of 1
      • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
      • The sticker does not need to be completely removed.
      Ask FixBot
    3. Ozeri Pronto ZK14-S LCD Replacement: step 3, image 1 of 1
      • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
      Ask FixBot
    4. Ozeri Pronto ZK14-S LCD Replacement: step 4, image 1 of 2 Ozeri Pronto ZK14-S LCD Replacement: step 4, image 2 of 2
      • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
      Ask FixBot
    5. Ozeri Pronto ZK14-S LCD Replacement: step 5, image 1 of 2 Ozeri Pronto ZK14-S LCD Replacement: step 5, image 2 of 2
      • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
      Ask FixBot
    6. Ozeri Pronto ZK14-S LCD Replacement: step 6, image 1 of 1
      • Turn the device over so the back panel is facing up.
      Ask FixBot
    7. Ozeri Pronto ZK14-S LCD Replacement: step 7, image 1 of 1
      • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
      Ask FixBot
    8. Ozeri Pronto ZK14-S LCD Replacement: step 8, image 1 of 1
      • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
      Ask FixBot
    9. Ozeri Pronto ZK14-S LCD Replacement: step 9, image 1 of 2 Ozeri Pronto ZK14-S LCD Replacement: step 9, image 2 of 2
      • Pry apart the two panels to separate them from each other.
      • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
      • Be careful when separating the panels to avoid damaging the wires they are connected by.
      Ask FixBot
    1. Ozeri Pronto ZK14-S LCD Replacement, LCD: step 10, image 1 of 2 Ozeri Pronto ZK14-S LCD Replacement, LCD: step 10, image 2 of 2
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
      Ask FixBot
    2. Ozeri Pronto ZK14-S LCD Replacement: step 11, image 1 of 3 Ozeri Pronto ZK14-S LCD Replacement: step 11, image 2 of 3 Ozeri Pronto ZK14-S LCD Replacement: step 11, image 3 of 3
      • Stand the center motherboard up to expose the LCD screen
      • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
      • Remove the LCD screen.
      Ask FixBot
3 other people completed this guide.
Oneika White
726 Reputation
4 Guides authored
USF Tampa, Team 1-4, Leahy Fall 2015 Member of USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 Members
60 Guides authored
1 Guide Comment
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
Dennis Lima - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 96
All Time: 1,291
