Ozeino OW810 Volume Buttons Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
68
All Time:
587
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
If your volume, power, or slide buttons are not working, use this guide to help fix or replace them.
Tools
    1. Ozeino OW810 Volume Buttons Replacement, Volume Buttons: step 1, image 1 of 1
      • Use a Metal Spudger to remove the ear muffs from the headset.
      Ask FixBot
    2. Ozeino OW810 Volume Buttons Replacement: step 2, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the 1st 9mm screw that secures the left head piece.
      Ask FixBot
    3. Ozeino OW810 Volume Buttons Replacement: step 3, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the 2nd 9mm screw that secures the left head piece.
      Ask FixBot
    4. Ozeino OW810 Volume Buttons Replacement: step 4, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the 3rd 9mm screw that secures the left head piece.
      Ask FixBot
    5. Ozeino OW810 Volume Buttons Replacement: step 5, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the 4th 9mm screw that secures the left head piece.
      Ask FixBot
    6. Ozeino OW810 Volume Buttons Replacement: step 6, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the 5th 9mm screw that secures the left head piece.
      Ask FixBot
    7. Ozeino OW810 Volume Buttons Replacement: step 7, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the last 9mm screw that secures the left head piece.
      Ask FixBot
    8. Ozeino OW810 Volume Buttons Replacement: step 8, image 1 of 1
      • Use your hands or the metal spudger to pry open the earpiece to find the green panel.
      Ask FixBot
    9. Ozeino OW810 Volume Buttons Replacement: step 9, image 1 of 1
      • After opening the ear piece find the green panel and look for the 1st 7mm screw. Use the Phillips #000 screwdriver to remove the screw that is holding the green panel in place.
      Ask FixBot
    10. Ozeino OW810 Volume Buttons Replacement: step 10, image 1 of 1
      • Use the Phillips #000 screwdriver to remove the 2nd 7mm screw that is holding the green panel in place.
      Ask FixBot
    11. Ozeino OW810 Volume Buttons Replacement: step 11, image 1 of 1
      • Using either your hand or the tweezers carefully remove the green panel from inside the headset.
      Ask FixBot
    12. Ozeino OW810 Volume Buttons Replacement: step 12, image 1 of 1
      • After removing the panel, use either your hands or tweezers to carefully remove and replace the volume and power buttons.
      Ask FixBot
    13. Ozeino OW810 Volume Buttons Replacement: step 13, image 1 of 1
      • Lastly, remove the slide button from the headset using a pair of tweezers.
      Ask FixBot
Jackson H. Jones
244 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 68
All Time: 587
