Ozeino OW810 Battery Replacement
  1. Ozeino OW810 Battery Replacement, Battery: step 1, image 1 of 1
    • Insert a nylon spudger in the seam between the right ear pad and the driver housing.
    • Pry the right ear pad off.
    Ask FixBot
  2. Ozeino OW810 Battery Replacement: step 2, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the six 3.2 mm screws securing the right driver housing.
    Ask FixBot
  3. Ozeino OW810 Battery Replacement: step 3, image 1 of 1
    • Lift the driver housing off, with care not to strain the connected cables.
    Ask FixBot
  4. Ozeino OW810 Battery Replacement: step 4, image 1 of 1
    • Use a nylon spudger to gently pry out the battery.
    • Do not use a metal spudger to pry out the battery. Metal spudgers can easily puncture the battery.
    Ask FixBot
  5. Ozeino OW810 Battery Replacement: step 5, image 1 of 1
    • Remove tape from the battery.
    • Pull the circuit board up along with the wiring from either side.
    • Replace battery.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Rylee
589 Reputation
3 Guides authored
1 Guide Comment
I recommend changing the difficulty to an easier setting. Additionally, it took a lot less time than 30 minutes. I recreated the steps in 8-10 minutes.
Morgan G - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 64
All Time: 639
