Ovation Acoustic Guitar String Replacement
    1. Ovation Acoustic Guitar String Replacement, Guitar String: step 1, image 1 of 1
      • Place the guitar neck where you can easily identify the broken string.
      Ask FixBot
    2. Ovation Acoustic Guitar String Replacement: step 2, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 2, image 2 of 2
      • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
      Ask FixBot
    3. Ovation Acoustic Guitar String Replacement: step 3, image 1 of 1
      • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
      Ask FixBot
    4. Ovation Acoustic Guitar String Replacement: step 4, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 4, image 2 of 2
      • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
      Ask FixBot
    5. Ovation Acoustic Guitar String Replacement: step 5, image 1 of 1
      • Layout the new guitar strings from biggest to smallest.
      Ask FixBot
    6. Ovation Acoustic Guitar String Replacement: step 6, image 1 of 3 Ovation Acoustic Guitar String Replacement: step 6, image 2 of 3 Ovation Acoustic Guitar String Replacement: step 6, image 3 of 3
      • Pull the new string through the bridge until the stopper is flushed with the bridge.
      Ask FixBot
    7. Ovation Acoustic Guitar String Replacement: step 7, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 7, image 2 of 2
      • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
      Ask FixBot
    8. Ovation Acoustic Guitar String Replacement: step 8, image 1 of 3 Ovation Acoustic Guitar String Replacement: step 8, image 2 of 3 Ovation Acoustic Guitar String Replacement: step 8, image 3 of 3
      • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
      Ask FixBot
    9. Ovation Acoustic Guitar String Replacement: step 9, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 9, image 2 of 2
      • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
      Ask FixBot
Finish Line
Rachel Galvan
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 52
All Time: 1,412
