Outdoor Gate Deadbolt Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
38
Past 30 Days:
272
All Time:
3,699
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
If the deadbolt in your gate is worn, malfunctioning, or damaged, you can easily replace it with a new one by following this guide. To do so, you will need a cross-head screwdriver and the new deadbolt.
There are a few common sizes for deadbolts. By using a tape measure to find the diameter of the pre-existing hole and the thickness of the gate, you can determine the correct choice for your gate.
    1. Outdoor Gate Deadbolt Replacement, Deadbolt: step 1, image 1 of 3 Outdoor Gate Deadbolt Replacement, Deadbolt: step 1, image 2 of 3 Outdoor Gate Deadbolt Replacement, Deadbolt: step 1, image 3 of 3
      • Remove the old deadbolt.
      • The gate should look like this before you begin installing the new deadbolt
      Ask FixBot
    2. Outdoor Gate Deadbolt Replacement: step 2, image 1 of 3 Outdoor Gate Deadbolt Replacement: step 2, image 2 of 3 Outdoor Gate Deadbolt Replacement: step 2, image 3 of 3
      • From the front side of the gate, push the latch into the center of the opening. Adjust as needed.
      • Screw both of the short screws into the panel to the right of the latch.
      Ask FixBot
    3. Outdoor Gate Deadbolt Replacement: step 3, image 1 of 3 Outdoor Gate Deadbolt Replacement: step 3, image 2 of 3 Outdoor Gate Deadbolt Replacement: step 3, image 3 of 3
      • Grab both of the long screws.
      • Adjust the back head of the doorknob to be facing in a straight upward position.
      • Screw in the long screws.
      • Make sure the screws are properly tightened.
      Ask FixBot
    4. Outdoor Gate Deadbolt Replacement: step 4, image 1 of 2 Outdoor Gate Deadbolt Replacement: step 4, image 2 of 2
      • The back end and the front face of the deadbolt must line up.
      • Screw in the screws until they are fully tightened.
      Ask FixBot
    5. Outdoor Gate Deadbolt Replacement: step 5, image 1 of 2 Outdoor Gate Deadbolt Replacement: step 5, image 2 of 2
      • Test out the new deadbolt with a key or door handle, depending on which one you may have.
      Ask FixBot
Kenneth
129 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 272
All Time: 3,699
