Outdoor Faucet Head Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
91
All Time:
1,831
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a tutorial on repairing leaking water pipes. Many houses are facing the problem of aging water pipes. If the water leak occurs in the middle of the night and a repairman cannot be found in time, we need to solve it by ourselves. This tutorial can help you replace the faucet head of an outdoor fixture. Be sure to turn off the water main during the repair to minimize leakage.
    1. Outdoor Faucet Head Replacement, Outdoor Faucet Head: step 1, image 1 of 1
      • Check the location of the water leakage, and turn off the water to that area.
      • Drain the water in the pipeline after it is determined, so as to avoid a large amount of water flowing out during the repair process.
      Ask FixBot
    2. Outdoor Faucet Head Replacement: step 2, image 1 of 1
      • Use a wrench to remove the leaking faucet by turning it counter-clockwise.
      • Be careful not to damage the water pipe.
      Ask FixBot
    3. Outdoor Faucet Head Replacement: step 3, image 1 of 2 Outdoor Faucet Head Replacement: step 3, image 2 of 2
      • Use PFTE tape to wrap the faucet mouth.
      • The purpose of this step is to prevent the faucet from still leaking after installation.
      Ask FixBot
    4. Outdoor Faucet Head Replacement: step 4, image 1 of 2 Outdoor Faucet Head Replacement: step 4, image 2 of 2
      • Install the replaced new faucet and confirm whether it is tightened.
      Ask FixBot
    5. Outdoor Faucet Head Replacement: step 5, image 1 of 1
      • Turn on the faucet and monitor whether the faucet is leaking. If not, the repair is over.
      Ask FixBot
There are no sharp objects used in the whole process, but you need to be careful that there may be places where the water pipes may be easily scratched.
Zelong jiao
268 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 91
All Time: 1,831
