Oster BLSTSS-PZO Circuitboard Replacement
    1. Oster BLSTSS-PZO Circuitboard  Replacement, Circuitboard: step 1, image 1 of 1
      • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
      Ask FixBot
    2. Oster BLSTSS-PZO Circuitboard  Replacement: step 2, image 1 of 1
      • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
      Ask FixBot
    3. Oster BLSTSS-PZO Circuitboard  Replacement: step 3, image 1 of 1
      • Gently remove the circuit board.
      Ask FixBot
    4. Oster BLSTSS-PZO Circuitboard  Replacement: step 4, image 1 of 2 Oster BLSTSS-PZO Circuitboard  Replacement: step 4, image 2 of 2
      • Use the spudger to detach the black wire from the circuit board.
      • Repeat for yellow wire.
      Ask FixBot
    5. Oster BLSTSS-PZO Circuitboard  Replacement: step 5, image 1 of 3 Oster BLSTSS-PZO Circuitboard  Replacement: step 5, image 2 of 3 Oster BLSTSS-PZO Circuitboard  Replacement: step 5, image 3 of 3
      • Use the Phillips #1 to remove the four 8mm screws.
      • Use the medal spudger to detach the circuit board from the buttons.
      • Gently pull and release circuit board from buttons.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
Where can I get a replacement part for this PCB assembly? My buttons stick and don’t work properly.
It’s the button pushing assembly that’s defective.
Jeff - Reply Share
Jeff - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 35
All Time: 1,162
