Oster BLSTSS-PZO Power Cord Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
87
All Time:
710
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The power cord is responsible for providing power to your device. This guide will instruct you on how to replace the power cord.
Tools
    1. Oster BLSTSS-PZO  Power Cord Replacement, Circuitboard: step 1, image 1 of 1
      • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
      Ask FixBot
    2. Oster BLSTSS-PZO  Power Cord Replacement: step 2, image 1 of 1
      • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
      Ask FixBot
    3. Oster BLSTSS-PZO  Power Cord Replacement: step 3, image 1 of 1
      • Gently remove the circuit board.
      Ask FixBot
    4. Oster BLSTSS-PZO  Power Cord Replacement: step 4, image 1 of 2 Oster BLSTSS-PZO  Power Cord Replacement: step 4, image 2 of 2
      • Use the spudger to detach the black wire from the circuit board.
      • Repeat for yellow wire.
      Ask FixBot
    5. Oster BLSTSS-PZO  Power Cord Replacement: step 5, image 1 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 5, image 2 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 5, image 3 of 3
      • Use the Phillips #1 to remove the four 8mm screws.
      • Use the medal spudger to detach the circuit board from the buttons.
      • Gently pull and release circuit board from buttons.
      Ask FixBot
    1. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: step 6, image 1 of 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: step 6, image 2 of 3 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: step 6, image 3 of 3
      • Locate petal prong on the end of the power cord.
      • Bend metal prong until it's straight with your finger.
      Ask FixBot
    2. Oster BLSTSS-PZO  Power Cord Replacement: step 7, image 1 of 2 Oster BLSTSS-PZO  Power Cord Replacement: step 7, image 2 of 2
      • Spring will pop out when you pull out metal prong
      • Pull prong out of the hole.
      Ask FixBot
    3. Oster BLSTSS-PZO  Power Cord Replacement: step 8, image 1 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 8, image 2 of 3 Oster BLSTSS-PZO  Power Cord Replacement: step 8, image 3 of 3
      • Pinch plastic prongs on base of blender to remove plastic securing device.
      • Remove plastic securing device.
      • Pull power cord out of blender base.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 87
All Time: 710
