Up to 20% off select tools
Oster 6329 Outer Shell Removal
Views: 3.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
102
All Time:
3,100
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing the outer shell is crucial to repairing any component of your toaster and must be done first before attempting any other guide.
    1. Oster 6329 Outer Shell Removal, Outer Shell Removal: step 1, image 1 of 2 Oster 6329 Outer Shell Removal, Outer Shell Removal: step 1, image 2 of 2
      • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
      Ask FixBot
    2. Oster 6329 Outer Shell Removal: step 2, image 1 of 1
      • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
      Ask FixBot
    3. Oster 6329 Outer Shell Removal: step 3, image 1 of 1
      • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
      • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
      Ask FixBot
    4. Oster 6329 Outer Shell Removal: step 4, image 1 of 2 Oster 6329 Outer Shell Removal: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
      Ask FixBot
    5. Oster 6329 Outer Shell Removal: step 5, image 1 of 2 Oster 6329 Outer Shell Removal: step 5, image 2 of 2
      • Lift the top outer metal shell.
      • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
      Ask FixBot
Author
with
Isaac Williams
237 Reputation
2 Guides authored
Cal Poly, Team 13-15, Regan Winter 2014 Member of Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 102
All Time: 3,100
