Oster 3905 Slot Levers Replacement
Views: 1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
102
All Time:
1,049
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
From frequent use, over time, slot levers may become unstable to the touch and fall off. This replacement guide will show you how to remove your current damaged levers. When doing this, you may feel like you are going to pull too hard, but do not worry about that. You will need to pull the on the slot levers with a lot of force.
    1. Oster 3905 Slot Levers Replacement, Slot Levers: step 1, image 1 of 1
      • Firmly grip your hand around the slot lever.
      Ask FixBot
    2. Oster 3905 Slot Levers Replacement: step 2, image 1 of 1
      • Stabilize the toaster by placing your hand on top.
      Ask FixBot
    3. Oster 3905 Slot Levers Replacement: step 3, image 1 of 2 Oster 3905 Slot Levers Replacement: step 3, image 2 of 2
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      Ask FixBot
    4. Oster 3905 Slot Levers Replacement: step 4, image 1 of 1
      • Both slot levers can be removed.
      Ask FixBot
Sydney Alcaraz
601 Reputation
3 Guides authored
CSU Fullerton, Team 2-1, Bruce Fall 2016 Member of CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 102
All Time: 1,049
