Up to 20% off select tools
Oster 3905 Lever Spring Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
97
All Time:
3,773
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the lever springs on your Oster 3905 toaster.
    1. Oster 3905 Lever Spring Replacement, Slot Levers: step 1, image 1 of 1
      • Firmly grip your hand around the slot lever.
      Ask FixBot
    2. Oster 3905 Lever Spring Replacement: step 2, image 1 of 1
      • Stabilize the toaster by placing your hand on top.
      Ask FixBot
    3. Oster 3905 Lever Spring Replacement: step 3, image 1 of 2 Oster 3905 Lever Spring Replacement: step 3, image 2 of 2
      • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
      Ask FixBot
    4. Oster 3905 Lever Spring Replacement: step 4, image 1 of 1
      • Both slot levers can be removed.
      Ask FixBot
    1. Oster 3905 Lever Spring Replacement, Outer Shell: step 5, image 1 of 1
      • Place the toaster upside down so the bottom is facing the ceiling.
      Ask FixBot
    2. Oster 3905 Lever Spring Replacement: step 6, image 1 of 2 Oster 3905 Lever Spring Replacement: step 6, image 2 of 2
      • Take off both rubber feet using a small metal spudger.
      • Wedge a spudger under the feet and pull up to pop off.
      Ask FixBot
    3. Oster 3905 Lever Spring Replacement: step 7, image 1 of 1
      • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
      • There are two screws under the rubber feet.
      Ask FixBot
    4. Oster 3905 Lever Spring Replacement: step 8, image 1 of 1
      • Place the toaster right side up.
      Ask FixBot
    5. Oster 3905 Lever Spring Replacement: step 9, image 1 of 2 Oster 3905 Lever Spring Replacement: step 9, image 2 of 2
      • Grab the outer shell firmly and pull up towards the face of the toaster.
      Ask FixBot
    6. Oster 3905 Lever Spring Replacement: step 10, image 1 of 1
      • For this part, you might need to wiggle the toaster to get the outer shell off.
      • The shell will not completely come off until the motherboard is removed in the next step.
      Ask FixBot
    7. Oster 3905 Lever Spring Replacement: step 11, image 1 of 3 Oster 3905 Lever Spring Replacement: step 11, image 2 of 3 Oster 3905 Lever Spring Replacement: step 11, image 3 of 3
      • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
      Ask FixBot
    8. Oster 3905 Lever Spring Replacement: step 12, image 1 of 2 Oster 3905 Lever Spring Replacement: step 12, image 2 of 2
      • Take out the grey “cancel” and “bagel” buttons from the shell.
      Ask FixBot
    1. Oster 3905 Lever Spring Replacement, Lever Spring: step 13, image 1 of 2 Oster 3905 Lever Spring Replacement, Lever Spring: step 13, image 2 of 2
      • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
      Ask FixBot
    2. Oster 3905 Lever Spring Replacement: step 14, image 1 of 2 Oster 3905 Lever Spring Replacement: step 14, image 2 of 2
      • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
      Ask FixBot
    3. Oster 3905 Lever Spring Replacement: step 15, image 1 of 3 Oster 3905 Lever Spring Replacement: step 15, image 2 of 3 Oster 3905 Lever Spring Replacement: step 15, image 3 of 3
      • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
      • Pull the metal spacer upwards to release from the toaster.
      Ask FixBot
    4. Oster 3905 Lever Spring Replacement: step 16, image 1 of 2 Oster 3905 Lever Spring Replacement: step 16, image 2 of 2
      • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
      Ask FixBot
Author
with
Sydney Alcaraz
601 Reputation
3 Guides authored
CSU Fullerton, Team 2-1, Bruce Fall 2016 Member of CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Members
72 Guides authored
2 Guide Comments
Where's the fix?
D Unger - Reply Share
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 97
All Time: 3,773
