Oster 16-Speed Blender Container Replacement
    1. Oster 16-Speed Blender Container Replacement, Container: step 1, image 1 of 2 Oster 16-Speed Blender Container Replacement, Container: step 1, image 2 of 2
      • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
      Ask FixBot
    2. Oster 16-Speed Blender Container Replacement: step 2, image 1 of 2 Oster 16-Speed Blender Container Replacement: step 2, image 2 of 2
      • Next, remove the lid from the Blender Container.
      Ask FixBot
    3. Oster 16-Speed Blender Container Replacement: step 3, image 1 of 2 Oster 16-Speed Blender Container Replacement: step 3, image 2 of 2
      • Flip the container on its side so that the bottom faces you.
      • Now rotate the bottom counter-clockwise to remove it from the container.
      Ask FixBot
    4. Oster 16-Speed Blender Container Replacement: step 4, image 1 of 2 Oster 16-Speed Blender Container Replacement: step 4, image 2 of 2
      • Now you will see the bottom of the blender blades once the bottom piece is removed
      • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
      Ask FixBot
    5. Oster 16-Speed Blender Container Replacement: step 5, image 1 of 1
      • Now your container is separated.
      Ask FixBot
With your container separated, it can now be replaced. To reassemble your device, follow these instructions in reverse order.
Dana
881 Reputation
5 Guides authored
Cal Poly, Team 12-37, Maness Spring 2014 Member of Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 35
All Time: 1,478
