Osmo Mobile Trigger Button Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
107
All Time:
3,565
Comments: 10
9 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The trigger button is the one of the most used buttons on the DJI Osmo Mobile, and this guide will serve to teach the device owner how to replace a broken or unresponsive trigger button.
Parts
Tools
    1. Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: step 1, image 1 of 2 Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: step 1, image 2 of 2
      • Remove gimbal from base handle by loosening round plate found at the top of the handle.
      Ask FixBot
    2. Osmo Mobile Trigger Button Replacement: step 2, image 1 of 2 Osmo Mobile Trigger Button Replacement: step 2, image 2 of 2
      • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
      • Carefully detach handle from gimbal and disconnect the cable that connects the two.
      Ask FixBot
    3. Osmo Mobile Trigger Button Replacement: step 3, image 1 of 1
      • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
      Ask FixBot
    4. Osmo Mobile Trigger Button Replacement: step 4, image 1 of 2 Osmo Mobile Trigger Button Replacement: step 4, image 2 of 2
      • Remove joystick by gently pulling away from handle
      Ask FixBot
    5. Osmo Mobile Trigger Button Replacement: step 5, image 1 of 3 Osmo Mobile Trigger Button Replacement: step 5, image 2 of 3 Osmo Mobile Trigger Button Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
      • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
      Ask FixBot
    6. Osmo Mobile Trigger Button Replacement: step 6, image 1 of 3 Osmo Mobile Trigger Button Replacement: step 6, image 2 of 3 Osmo Mobile Trigger Button Replacement: step 6, image 3 of 3
      • Locate four screws directly on top of handle.
      • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
      • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
      • Remove the remaining two screws found on the front of the faceplate.
      • Remove the rest of the face plate shell.
      Ask FixBot
    1. Osmo Mobile Trigger Button Replacement, Charging Port: step 7, image 1 of 1
      • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
      • Lift faceplate holding joystick module.
      Ask FixBot
    2. Osmo Mobile Trigger Button Replacement: step 8, image 1 of 1
      • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
      Ask FixBot
    3. Osmo Mobile Trigger Button Replacement: step 9, image 1 of 1
      • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
      Ask FixBot
    4. Osmo Mobile Trigger Button Replacement: step 10, image 1 of 1
      • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
      • Replace charging module.
      Ask FixBot
    1. Osmo Mobile Trigger Button Replacement, Trigger Button: step 11, image 1 of 2 Osmo Mobile Trigger Button Replacement, Trigger Button: step 11, image 2 of 2
      Buy
      • Use the tweezers to push outward on the backside of the trigger button hinges.
      • Pop out trigger button.
      Ask FixBot
    2. Osmo Mobile Trigger Button Replacement: step 12, image 1 of 1
      • Use the tweezers to remove the underlying button that contacts with the trigger button, and replace.
      Ask FixBot
William Tyler Wills
432 Reputation
4 Guides authored
USF Tampa, Team S2-G1, Nance Fall 2017 Member of USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 Members
72 Guides authored
1 Guide Comment
How I can fix the USB port, it went inside the handle?
Juan Carlos Beltran - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 107
All Time: 3,565
