Up to 20% off select tools
Osmo Mobile Handle Disassembly
Views: 12K
View statistics:
Past 24 Hours:
8
Past 7 Days:
50
Past 30 Days:
206
All Time:
11,515
Comments: 19
9 comments on steps, 10 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Learn how to take apart the Osmo Mobile handle in order to gain access to other repairs such as the joystick, Bluetooth apparatus, trigger buttons and the charging port.
    1. Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: step 1, image 1 of 2 Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: step 1, image 2 of 2
      • Remove gimbal from base handle by loosening round plate found at the top of the handle.
      Ask FixBot
    2. Osmo Mobile Handle Disassembly: step 2, image 1 of 2 Osmo Mobile Handle Disassembly: step 2, image 2 of 2
      • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
      • Carefully detach handle from gimbal and disconnect the cable that connects the two.
      Ask FixBot
    3. Osmo Mobile Handle Disassembly: step 3, image 1 of 1
      • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
      Ask FixBot
    4. Osmo Mobile Handle Disassembly: step 4, image 1 of 2 Osmo Mobile Handle Disassembly: step 4, image 2 of 2
      • Remove joystick by gently pulling away from handle
      Ask FixBot
    5. Osmo Mobile Handle Disassembly: step 5, image 1 of 3 Osmo Mobile Handle Disassembly: step 5, image 2 of 3 Osmo Mobile Handle Disassembly: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
      • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
      Ask FixBot
    6. Osmo Mobile Handle Disassembly: step 6, image 1 of 3 Osmo Mobile Handle Disassembly: step 6, image 2 of 3 Osmo Mobile Handle Disassembly: step 6, image 3 of 3
      • Locate four screws directly on top of handle.
      • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
      • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
      • Remove the remaining two screws found on the front of the faceplate.
      • Remove the rest of the face plate shell.
      Ask FixBot
4 other people completed this guide.
Author
with
Ustena Safa
378 Reputation
2 Guides authored
USF Tampa, Team S2-G1, Nance Fall 2017 Member of USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 Members
72 Guides authored
10 Guide Comments
Bonjour,
La toute première étape est trop vague pouvez-vous donner plus de détails svp.
Je vous remercie d’avance
Guitt97ii - Reply Share
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
John M O'Donovan - Reply Share
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
Juan Carlos Beltran - Reply Share
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
michelle Moore - Reply Share
Your help would be greatly appreciated
Emile Jansen - Reply Share
Past 24 Hours: 8
Past 7 Days: 50
Past 30 Days: 206
All Time: 11,515
