Ortizan X10 LED Board Replacement
    1. Ortizan X10 LED Board Replacement, Grille: step 1, image 1 of 2 Ortizan X10 LED Board Replacement, Grille: step 1, image 2 of 2
      • Use an opening tool to remove the rubber end caps.
      Ask FixBot
    2. Ortizan X10 LED Board Replacement: step 2, image 1 of 3 Ortizan X10 LED Board Replacement: step 2, image 2 of 3 Ortizan X10 LED Board Replacement: step 2, image 3 of 3
      • Use a Phillips screwdriver to remove the four screws (two on each end).
      • Firmly grip the top of the speaker, stabilize the base, and twist the cap counterclockwise to loosen and remove. Repeat this step for the bottom cap.
      Ask FixBot
    3. Ortizan X10 LED Board Replacement: step 3, image 1 of 1
      • Insert an opening tool into the seam between the grille and body. Lift and crack it open just a little.
      Ask FixBot
    4. Ortizan X10 LED Board Replacement: step 4, image 1 of 1
      • Using your hands, pull the speaker out of the casing by holding the speaker in one hand and the shell in the other.
      Ask FixBot
    1. Ortizan X10 LED Board Replacement, LED Board: step 5, image 1 of 2 Ortizan X10 LED Board Replacement, LED Board: step 5, image 2 of 2
      • You can use the iFixit Opening Tool to carefully remove the silicone protective covers at the speaker's top and bottom.
      Ask FixBot
    2. Ortizan X10 LED Board Replacement: step 6, image 1 of 1
      • Using the Mahi driver kit and a 1.5 screwdriver bit, remove the two screws that secure the top and bottom of the speaker. Apply firm, even pressure while turning counterclockwise.
      Ask FixBot
    3. Ortizan X10 LED Board Replacement: step 7, image 1 of 2 Ortizan X10 LED Board Replacement: step 7, image 2 of 2
      • After removing the screws, firmly grip the top, stabilize the base, and turn the top counterclockwise (to the left) to loosen and detach it. Repeat the same steps to remove the other side.
      Ask FixBot
    4. Ortizan X10 LED Board Replacement: step 8, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the screw that secures the LED circuit board.
      Ask FixBot
    5. Ortizan X10 LED Board Replacement: step 9, image 1 of 1
      • Use a pair of tweezers to carefully flip up the small locking flap on the ZIF connector.
      Ask FixBot
    6. Ortizan X10 LED Board Replacement: step 10, image 1 of 1
      • Use tweezers to gently lift the locking flap on the ZIF connector to release the ribbon cable.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Vainavi
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 331
