Oreva FX-82MS Battery Replacement
    1. Oreva FX-82MS Battery Replacement, Battery: step 1, image 1 of 1
      • Turn off the calculator by pressing the [Shift] button and then press the [AC][OFF] button, (while keeping the [Shift] button pressed down).
      Ask FixBot
    2. Oreva FX-82MS Battery Replacement: step 2, image 1 of 2 Oreva FX-82MS Battery Replacement: step 2, image 2 of 2
      • Flip the calculator over so that the back panel faces up.
      • Use a Phillips #0 screwdriver to remove six, 1.2 mm screws starting from the upper right corner.
      Ask FixBot
    3. Oreva FX-82MS Battery Replacement: step 3, image 1 of 2 Oreva FX-82MS Battery Replacement: step 3, image 2 of 2
      • Remove the back cover and put it to the side.
      Ask FixBot
    4. Oreva FX-82MS Battery Replacement: step 4, image 1 of 2 Oreva FX-82MS Battery Replacement: step 4, image 2 of 2
      • Remove the two old batteries from the slots.
      • Be gentle when removing the batteries to avoid damaging the connectors.
      Ask FixBot
    5. Oreva FX-82MS Battery Replacement: step 5, image 1 of 3 Oreva FX-82MS Battery Replacement: step 5, image 2 of 3 Oreva FX-82MS Battery Replacement: step 5, image 3 of 3
      • Place the two new AAA batteries into the calculator, one by one.
      • Be sure that the direction of the + and - signs on your battery match the signs at the bottom of the battery compartment.
      • Place the case on back of the calculator.
      Ask FixBot
    6. Oreva FX-82MS Battery Replacement: step 6, image 1 of 2 Oreva FX-82MS Battery Replacement: step 6, image 2 of 2
      • Use a Phillips #0 screwdriver to replace the 1.2 mm screws on the back case.
      Ask FixBot
    7. Oreva FX-82MS Battery Replacement: step 7, image 1 of 1
      • Reset the calculator by pressing [ON].
      • Press the [shift] button.
      • Press the [9] [CLR] button to clear the data.
      • Press the [3][ALL] button option.
      • Press [=] [yes] button to agree.
      • Press [AC] key to reset.
      Ask FixBot
2 other people completed this guide.
Prarthit patel
196 Reputation
1 Guide authored
3 Guide Comments
Half Display Of Oreva Fx-82 MS Scientific calculator Half Display is not showing How to Fix it?
Devanshu Prajapati - Reply Share
অন হচ্ছে না
Sakib Islam - Reply Share
ক্যালকুলেটর অন হচ্ছে না
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 116
All Time: 4,638
