Oregon Scientific RM318PA Power Switch Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
97
All Time:
2,077
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will assist you in removing the back casing of the clock to access the on/off switch and put it back in place.
Tools
    1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: step 1, image 1 of 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: step 1, image 2 of 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: step 1, image 3 of 3
      • Hold clock so that the clock face is facing away from you.
      • Using your thumbs, push up on the battery cover.
      • Once battery cover is removed, pull down on AC Adapter Jack.
      Ask FixBot
    2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: step 2, image 1 of 1
      • Use one hand to stabilize the clock.
      • Using your other hand, push batteries toward spring and pull out at an angle.
      Ask FixBot
    3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: step 3, image 1 of 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: step 3, image 2 of 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: step 3, image 3 of 3
      • Use a Plastic Opening Tool to pry off the silver casing on the back.
      • Pry at the top of device.
      • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
      • On/Off switch should come off with casing.
      Ask FixBot
    4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: step 4, image 1 of 2 Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: step 4, image 2 of 2
      • Insert switch into slot as shown in picture. Push in until you hear a "click."
      • Replace the back of the clock by pressing cover back into place.
      Ask FixBot
3 other people completed this guide.
Maxine Holden
500 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 97
All Time: 2,077
