Oregon Scientific RM318PA A/C Power Adapter Replacement
  1. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: step 1, image 1 of 2 Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: step 1, image 2 of 2
    • To access the A/C Power Adapter connection, remove the battery cover, located on the back of the clock.
    Ask FixBot
  2. Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: step 2, image 1 of 2 Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: step 2, image 2 of 2
    • To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
    Ask FixBot
  3. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Socket: step 3, image 1 of 1
    • Gently pull the A/C Power Adapter from the socket, to the left of the batteries.
    Ask FixBot
  4. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Tip: step 4, image 1 of 1
    • To plug in the A/C Power Adapter, insert the tip into the socket, located to the left of the batteries, and press firmly.
    • Be sure that you are inserting an A/C Power Adapter and not a D/C Power Adapter. Inserting the improper cord could cause damage to the device.
    Ask FixBot
  5. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Cord: step 5, image 1 of 1
    • Once the A/C Power Adapter tip is inserted in the socket, guide the cord through a notch directly below.
    Ask FixBot
Maxine Holden
500 Reputation
4 Guides authored
4 Guide Comments
i need operating manual for model no.rm318pa.please send to…gjgeoff1@outlook.fr
jean-guy geoffroy - Reply Share
i need operating manuel
When you say make sure to insert AC power adapter what do you mean. It clearly says DC3V on the clock. Could you post the picture of the adapter without cord over the label?
Alex Olekh - Reply Share
Alex! Yes, right you are! DC not AC and Oregon Scientific will not answer my email requests. I am !#^&@@!
Ty Ford - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 56
All Time: 4,657
