Oregon Scientific Meep! 4.0 Screen Replacement
    1. Oregon Scientific Meep! 4.0 Screen Replacement, Oregon Scientific Meep! 4.0 Disassembly: step 1, image 1 of 1
      • Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
      Ask FixBot
    2. Oregon Scientific Meep! 4.0 Screen Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to detach the clips on the inside of the device.
      Ask FixBot
    1. Oregon Scientific Meep! 4.0 Screen Replacement, Screen: step 3, image 1 of 1
      • Remove the black tape holding the battery in place.
      Ask FixBot
    2. Oregon Scientific Meep! 4.0 Screen Replacement: step 4, image 1 of 1
      • Use a spudger to separate the battery from its adhesive.
      Ask FixBot
    3. Oregon Scientific Meep! 4.0 Screen Replacement: step 5, image 1 of 1
      • Use a screwdriver to unscrew the three 4.0 mm Philips #00 screws holding the motherboard in place.
      Ask FixBot
    4. Oregon Scientific Meep! 4.0 Screen Replacement: step 6, image 1 of 1
      • Use a plastic opening tool and place the tip in between the white and black pieces holding in the ribbon cable in to release the three ribbon cables around the motherboard.
      Ask FixBot
    5. Oregon Scientific Meep! 4.0 Screen Replacement: step 7, image 1 of 1
      • Remove the motherboard and unscrew the twelve 7.0 Phillips #00 screws holding the metal casing around the screen in.
      Ask FixBot
    6. Oregon Scientific Meep! 4.0 Screen Replacement: step 8, image 1 of 1
      • Use a plastic opening tool to undo the metal clips holding the screen in place.
      Ask FixBot
    7. Oregon Scientific Meep! 4.0 Screen Replacement: step 9, image 1 of 1
      • Remove the plastic over the screen and use a spudger or plastic opening tool to remove the screen from the sticky adhesive.
      Ask FixBot
Lauren Milici
216 Reputation
2 Guides authored
2 Guide Comments
bonjour
où trouver l 'écran sil vous plait ?
merci
bob bob - Reply Share
je cherche pour en acheter un et j en trouve nul part
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 48
All Time: 647
